cjs42079
- Joined
- May 10, 2022
- Messages
- 96
- Reaction score
- 232
hey guys, sorry for the new thread…but this is kinda cool.
I have a SJ 2525H. I’m going to assume this works similarly on the originals as well.
Anyway, typically the way I would run the clean channel is to get the input gain up to at least 6 or 7, and get some real nice but subtle overdrive going on when you dig in. Master volume maybe on 7 or 8. I would also use the footswitch and hit the lead channel at full gain. Everything sounds lovely. Amazing. Except I find it difficult to precisely manage the volume between channels correctly and I also run out of headroom real quick, not getting as much db boost as I usually like on certain parts.
Now the controversial move: I heard recently that Frusciante is using his with the rhythm clip pulled on the clean channel, and the input gain turned down really far, like 1 or 2. So I tried it and you know what…it sounds almost exactly the same as my original setup without the clip pulled and the IG on 6…except it’s even sweeter. It has a little extra touch to it. And the best part of all, I have tons of headroom available. I boost left right and all over the place. And I can switch channels and set my lead gain lower than before! Kind of amazing.
Am I nuts? Discuss…
Am I nuts? Discuss…
