Matthews Guitars
- Joined
- Aug 17, 2019
- Messages
- 6,382
- Reaction score
- 10,300
So for the first time since my good friend/amp guru died, one of his creations has come to roost upon my workbench in need of repair.
It's a modded Laney AOR, originally a 100 watter, converted to 50 watts, with a lot of other mods done as well. Basically as I understand it, it's been converted to a circuit similar to that of a 2204 but with an added tube and two added gain stages. I can't verify how much was done to the in-chassis wiring, but the PC board is close to stock. (I've got spare AOR PC boards taken from other amps in the past to use as a reference.)
Symptom is no audio from the guitar inputs, but jacking into the FX loop input shows that the power amp is working.
I'm still figuring out the actual circuit topology. I have no documentation (that I have found yet) on this modified amp. I'm learning as I go. That includes digging in the filing cabinet that has my friend's stored documentation which SHOULD include the docs on this amp.
To do rapid and effective signal path tracing, I use an audio generator and an oscilloscope. This has caused me to find that on V2B, there is signal input on the grid but no signal output on the plate or on the cathode bypass capacitor either. . Plate voltage is healthy at around 230 volts. Tube socket is good, known good tubes have been checked in the socket.
I'm thinking that the output coupling cap on the output of the cathode follower has failed. I'll be testing this diagnosis tomorrow.
The weirdest thing about the mod is that the two stages that comprise the cathode follower and gain stage span across two separate tube sockets. The plate-to-grid jumper wire runs from socket V3 to socket V4.
