Show me your Variac
Discussion in 'The Workbench' started by Rotorcraft230, Jun 27, 2020.
  1. Rotorcraft230
    Rotorcraft230 Well-Known Member Premium Member
    Aug 15, 2019
    441
    299
    Brazoria County Texas
    DE941B72-9FD9-489E-9F07-85D272958CEE.jpeg I finally bought a Variac. A bit unusual with the black wrinkle finish. Works great all original and a great price. Paid 75 bucks shipped. Anybody know what year it may have come from?
    show me yours
    Mark
    Exotic, jmp45 and Biddlin like this.
  2. Biddlin
    Biddlin Well-Known Member
    Aug 21, 2013
    4,063
    4,599
    Old Foothill Farms, Califusa
    I'd have to ask my proctologist for the Xrays.
    Exotic likes this.
  3. Exotic
    Exotic Well-Known Member
    Sep 3, 2018
    558
    441
    well ,tell us how u do? can u turn the variac way down and blast the amp ,and presto u sound like eddie van halen on vh1? album?
  4. Rotorcraft230
    Aug 15, 2019
    441
    299
    Na it’s for building and repairing amps.
    In suppose you can use it for that, like the EVH thing
    Exotic likes this.
  5. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,239
    943
    Yours looks vintage. I got a used one recently but opted to get one with a 3-prong plug and receptacle. And, no, not using to sound like Eddie. I’m using mine to bring my builds up to power slowly. It cost $110 off the bay.
    Exotic likes this.
  6. Rotorcraft230
    Aug 15, 2019
    441
    299
    Nice, kinda hate to mod it but I think I should. 3 prong power chord and I’ve already made this to adapt for the output. Just need a longer screw and a spacer to attach the alligator clip to
    Exotic and Chris-in-LA like this.
  7. william vogel
    william vogel Active Member
    Dec 18, 2016
    105
    103
    I don’t know 100% if this is true but I read that the first time EVH plugged in his Marshall, it went up in smoke. He got a variac to lower the voltage. Is it possible it was a 100 volt model?
    Exotic likes this.
  8. South Park
    2,500
    2,025
    Exotic likes this.
  9. Chris-in-LA
    Jul 19, 2018
    1,239
    943
    I heard Ed do an interview recently and he said he bought his first Marshall, tried to make it work, but had it on the 240v setting. That experience got him thinking that he could experiment with different voltages for his amp and that led him to getting the variac. Don’t know if he blew it up or not.
    I think this was the interview, either way it was interesting.
    Exotic likes this.
  10. Sapient
    Sapient Well-Known Member
    Mar 14, 2020
    865
    1,630
    Yes
    The crunch I get out of my PLEXIs is outstanding now. Finally ..more control. :yesway:
  11. william vogel
    Dec 18, 2016
    105
    103
    I read that he was working in a club and they had an old plexi in the back line. They never used it and ed talked them into paying him with the amp for his hours worked. When he finally got it, he took it home and plugged it in. Smoke Cloud!!
    Could have had bad caps but this was the whole variac thing. I’m just wondering if it was a 100 volt and he had to use the variac to get the amp happy. Ed’s ego gets in the way of the truth. He let Dave talk him into lying about the variac and I just wonder if there’s more to the story. I’ve variaced down to 90 volts and loose to much of the amp from 120 volts. 90 into 100 seems about the right ratio for 120 into a 100 volt design.
    Exotic likes this.
  12. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,107
    1,010
    house arrest
    I am hoping to use variac's to get these tones with the SV20 soon. EVH had great results. At least through his PLexi's. Especially 12301
    Exotic likes this.
  13. Seanxk
    Seanxk Well-Known Member
    May 14, 2018
    404
    330
    Out of interest, what Amp rating is it.
    Exotic likes this.
  14. Rotorcraft230
    Aug 15, 2019
    441
    299
    amp rating is 7.5. Plenty for what I want to use it for
    Edit. These Powerstats made by Superior Electric are built like tanks, that’s why there are a lot of them still out there I think mine is from the 50s. It weight probably 12 pounds.
    Exotic and Seanxk like this.
  15. Rotorcraft230
    Aug 15, 2019
    441
    299
    They started making then in 1938
    Exotic likes this.
  16. junk notes
    Dec 10, 2018
    1,107
    1,010
    house arrest
    Sure. Listen to what I posted and then decide.
    Exotic likes this.
  17. Chris-in-LA
    Jul 19, 2018
    1,239
    943
    I’ve heard people say that if you let an amp sit for a long time you should bring it up slowly. I would assume that could be another use for a variac. But, how slow is slowly?
    Exotic likes this.
  18. South Park
    2,500
    2,025
    What you are doing is resetting the filter caps to a certain voltage . It is what a lot of raideo repair techs do to really old stuff. You ramp it up 50 volts a hour . What is nice to do with a Variac is power up a new build on low voltage to test amp draw . The transformers don’t care just don’t run the tubes on low voltage
    Exotic likes this.
  19. Chris-in-LA
    Jul 19, 2018
    1,239
    943
    Quick question, no tubes but what about a tube rectifier? I assume that you will not send any b+ to the filter caps without a rectifier.
    Exotic likes this.
  20. neikeel
    4,379
    2,812
    The easiest way with a tube rectifier is not to use the variac. take a 2w 100k resistor and clip it across the terminals if the stand by switch. All tubes out except rectifier.
    Switch amp on (but not the St by). Now all the HT is going through the amp and the 100k limits the current. As the caps reform the voltage on the caps goes up snd the voltage drop across the 100k goes down. It will start at 200v plus, drop to 70v After a few mins and, depending on the condition of the caps, dropping slowly over a few hours. Good caps will be down below 2vdc within 4-6 hours. Satisfactory, but not perfect, under 10vdc.
