Sd1 noisy as hell? X2
Discussion in 'The Tone Zone' started by GregM, Oct 24, 2021.
  1. PelliX
    PelliX Well-Known Member
    Jun 16, 2020
    1,599
    2,982
    Figures. I had my RC-3 open just for fun and because I was wondering how they implemented the storage and USB. All SMD.
  2. jeffb
    jeffb Well-Known Member
    Oct 11, 2011
    1,204
    2,190
    YES.
    I've only had old ones from the 1980s, but
    HELL YES. Noisy.
    Most BOSS designs from BITD were noisy.
  3. HOT TUBES 70
    Oct 13, 2008
    11,285
    5,850
    How old is your SD1 ?
    Do you have the serial number from the battery compartment ?
  4. HOT TUBES 70
    Oct 13, 2008
    11,285
    5,850
    If its old , it could just need a freshen up internally !
    Caps dry out , tone suffers , noise happens .
    VERVEHAMMER likes this.
  5. crossroadsnyc
    Feb 5, 2009
    21,944
    22,360
    Nope, that's not normal. I haven't a clue as to why it's making that noise, but it shouldn't.
    Edgar Frog and Mitchell Pearrow like this.
  6. HOT TUBES 70
    Oct 13, 2008
    11,285
    5,850
    Ive fixed a lot of noise issues with the SD1 due to old dried out caps .
  7. Scallywag77
    Scallywag77 Active Member
    Mar 26, 2021
    49
    134
    Return it or use the warrenty. If the new one does the same thing then something else going on.
    80sTone likes this.
  8. 80sTone
    80sTone Well-Known Member
    Nov 10, 2011
    297
    365
    Agree here, just return it....Should be quiet - probably a an anomoly but if you get a second and an issue It probably is not the stomper
    Edgar Frog likes this.
  9. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    460
    775
    SD-1 is a quiet pedal - send it back, get another one.
  10. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    10,394
    10,085
    North
    I took mine apart for the same reason. I thought it might have bad connection but it looks ok. What kind of mods do you do. I forgot it’s been a while.
