Screen Voltage Limit
Discussion in 'The Workbench' started by z808, Dec 7, 2021.
  1. z808
    z808 New Member
    Oct 27, 2015
    18
    Quick question here:
    I have installed JJ 6L6GC tubes in my Marshall. The screen g2 max voltage is 450 volts according to the data sheet from JJ. After biasing, I have a screen voltage of about 453 +/- volts. Is this O.K. since it is over by a few volts?
  2. Ken Underwood
    Oct 16, 2013
    785
    1,971
    Torquay, South Devon UK.
    Cannot see that will make any difference at all, also consider how accurate your meter is too.
    Data sheets no matter what they are for will always have a tolerance +/-, so 3 volts will be an extremly low tolerance.
    What type of meter are you using??
  3. z808
    z808 New Member
    Oct 27, 2015
    18
    I was using a Klein Tools TRMS multimeter. I do have a Fluke on hand just need to find it.
  4. EADGBE
    EADGBE Well-Known Member
    Dec 13, 2009
    739
    747
    Old Punker and z808 like this.
  5. Ken Underwood
    Oct 16, 2013
    785
    1,971
    Make comparisons then with the Fluke, but at the end of the day you are worrying about nothing.
  6. z808
    z808 New Member
    Oct 27, 2015
    18
    Thanks Ken, appreciate the feedback.
  7. Old Punker
    Old Punker Well-Known Member
    Jun 17, 2020
    1,559
    4,398
    Ontario, Canada
    Not an expert here but won't the HV level vary with the mains voltage anyway? :scratch:
    Even so, you're only over by 0.7%. :thumb:
    z808 and Pete Farrington like this.
  8. Pete Farrington
    Jan 18, 2021
    916
    928
    Staffordshire UK
    Note that 6L6GC screen grids are good for 500V when UL connected, so from that, it may be inferred that idle voltage is of somewhat limited relevance; class AB amps don’t tend to fail / undergo stress at idle.
    The HT voltages, especially that of the screen grid, will drop, generally significantly so, when the amp generates some output power. That’s when the compliance to its voltage limit needs to be verified. https://tubedata.altanatubes.com.br/sheets/093/6/6L6GC.pdf.
    z808, Old Punker and XTRXTR like this.
