SC20 or SV20? or other?
Discussion in 'Marshall Amps' started by PMJ, Oct 22, 2020.
  1. PMJ
    PMJ Member
    Oct 22, 2020
    22
    30
    Hi, i'm looking for a JMP 2203/2204 sound in a portable package (15kg or less, preferably smallish box).
    The SC20 or SV20 seem like a good option, but I know they don't have the juice or low end of the big brothers.
    Would there be another amp that is close to the JMP with my weight/size requirements, or should i get one of the studio heads? in that case, which is closest? SC or SV? to my ears SC is closer but I haven't tried any in person yet so it might not be an accurate judgement.
    thanks
  2. Jethro Rocker
    8,731
    11,228
    The SC IS a 2204 in a smaller package. Whether the lack of low end is a big difference to you you would have to listen. If you get the head and have an existing cab it will sound closer than the combo. You gotta listen but the SC is exacrly that.
  3. pedecamp
    15,638
    13,508
    SC20 is a 20 watt 2203 bud. :yesway:
  4. PMJ
    PMJ Member
    Oct 22, 2020
    22
    30
    allright, my understanding was that the JMP2203/2204 was different from the JCM800 2203/2204, and that it might be somewhere between a JMP1959 and a JCM800 2203/2204, guess i was wrong!
    guess i'll get a SC20 then, shame there is no way to make a JCM800 50watter portable, 20kg for the reissue head is too much for me especially with it's bulky size.
    scozz, Mitchell Pearrow and tce63 like this.
  5. dro
    dro Well-Known Member
    Aug 1, 2015
    824
    1,409
    Blue Springs Mo
    It could be portable if you put it in the type of case I've got my JTM in.
    Just lean on it
  6. tce63
    Aug 6, 2018
    1,792
    4,778
    Sweden
    I think you need the SC20H, I have both the SV20H and SC20H
    AND :welcome: to the forum
    Cheers :cheers:
    ChuggyMcBr00tlz, T.J., scozz and 5 others like this.
  7. PMJ
    PMJ Member
    Oct 22, 2020
    22
    30
    thanks for the welcome!
  8. PMJ
    PMJ Member
    Oct 22, 2020
    22
    30
    do you mean it would be closer because the combo is a 10"? not because the head version sounds bigger than the combo version if they would be both plugged into the same cab?
    scozz and tce63 like this.
  9. Jethro Rocker
    8,731
    11,228
    Right. Plugged into same cab they are the same amp.
    Admittedly, some JMP will sound different from some JCM but then again, some JCM sound slightly different from one another given the tolerances of components at the time.
    With the master volume system, the SC20 is the smallest version of the 2203. A 50 watter, while not much louder than the 20 watt, does have larger transformers so it has to be heavier. That is likely partly why they sound a bit better on the low end.
    scozz, PMJ, Mitchell Pearrow and 2 others like this.
  10. pedecamp
    15,638
    13,508
    You could use a re-amper to bump the SC20 to 50 watts and even 100 watts if you want. Take a look at the Bad Cat Unleash for example.
  11. Jethro Rocker
    8,731
    11,228
    Whether that alone provides the low end thump sorta loss from the smaller iron I dunno. But hey put an EQ in the loop amd go!
    scozz, PMJ, tce63 and 2 others like this.
  12. Mitchell Pearrow
    12,185
    22,057
    Welcome to the forum
    SC 20 all day, then get the SV 20.
    Cheers
    Mitch
    Trelwheen, T.J., scozz and 5 others like this.
  13. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,412
    3,737
    C-137
    :agreed:
    Someday, Marshall will take their heads outta their ass and add a MV to something like the SV20.
    I understand and know the circuit/component differences between a 2203 and 1959...
    A well designed MV (*cough* Friedman *cough*) in a plexi circuit is king.
  14. Mitchell Pearrow
    12,185
    22,057
    Way back in the very early 80’s my buddy Rick had the 1987 with the MV mod done to it, that had to be my favorite amp ever.
    Man I can tell ya that after a long lay off of playing guitar, when I purchased my Dsl40c’s I had a bit of a learning curve to know how to dial one of them in ha ha.
    Cheers
    Mitch
  15. Jethro Rocker
    8,731
    11,228
    Wouldnt a volume in loop work to that extent? Also, isnt the SC20 going to be real close?
    scozz, DonP and Mitchell Pearrow like this.
  16. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,343
    1,316
    Ceriatone 2202 in a combo. http://www.ceriatone.com/british-style-2202/ Way more bang for your buck. This is what they say on the 2202 page:
    "The 2202 started with the preamp of our 2203HW and 2204HW, but we added some features to make a timeless design even more flexible.
    In the preamp, we added a 3-way Bright switch, which not only helps dial in the high frequency content, but also adds another means of sculpting the gain structure of the amplifier. Next, we added a powerful Boost switch, which defeats the tonestack and adds some serious gain and harmonic complexity. If that wasn’t enough, we added a Fat switch that was inspired by our OTS series. This changes the frequency of the Treble control, vastly thickening the midrange.
    The power amp wasn’t safe either. We added a specially tuned Resonance control to help add thump and authority. Finally, and perhaps most importantly, we added a Post-Phase Inverter Master Volume that is so good, you can sell your attenuators for MOAR AMPSZ.
    Oh, we can’t forget to mention this is all in a small chassis using 6V6s to put out a rotund 20W of power."
    $625 head
    $745 Combo (without speaker) I would put in a 75w CB I think.
    Darkburst likes this.
  17. marshallmellowed
    Jun 26, 2009
    4,123
    5,548
    If you're looking for the "master volume" sound, get the SC20. If you're looking for the "non-master volume" sound, get the SV20. Simple as that.
    scozz, LPMarshall hack, PMJ and 4 others like this.
  18. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    788
    1,800
    SC20H in the Studio Series fits your requirements for a portable JCM800.
    I have the SV20H and 2525H. I use a 2061CX 2x12 cabinet with either one. Sometimes an open back 1x12 with the SV. Great sounding if a 20 watt head fits your needs.
  19. scozz
    Jul 20, 2008
    4,127
    9,222
    Yes, right on point Jethro, an eq in the loop is a good way to get a bit more low end from a SC20 or any other amp. I have one, and I use to use it to boost the low end a little.
    I don’t use it much anymore because I also have a full size TC Electronics Spark Boost pedal with a full eq section. I like what the Spark does a bit better than the eq pedal.
    I use the Spark as mostly a clean boost and low end boost. The Spark is on all the time, I’m an at home player so the Spark gives me a bit of boost and helps me get a better low end at moderate volumes.
  20. Jethro Rocker
    8,731
    11,228
    Yeah I will probably use an OD with 2 or 3 band EQ up front most of the time with mjne which can reinitiate any lost bass.
    Sustainium and scozz like this.
