El Gringo
That's exactly right . Remember the sweet spot !I've actually never dimed an amp because I didn't like the tone when it started to get too loud
Seems you'd be out of the sweet spot anyway. Yo biz though.![]()
I was not able to go past double 7's on both output master and lead master and got what you talk about . I also believe it has a lot to do with the size of the room . Now having said that IMHO anything past double 5's which is where I normally operate is massively call the cops loud , which for me is the sweetspot for my set up .
We are thinking alike , as I love the compression . Also I don't need any overdrive /distortion pedals . Generally speaking you can only go so high on the volume before that mush appears , which is not good tone .I find I like the sound at 5 better than 6 or 7. I generally dislike poweramp distortion but i like when it starts to compress.
Out of curiosity talking about too much volume , if you use more speaker cabs could that offset the mush /yuck tone of going to 10 ? Or is it the same effect except with the sound coming out of more cabs and speakers . I hope my question makes sense ?If it wasnt safe they wouldnt make the dials to go to 10, but putting an amp on 10 may not always produce the best sound but can handle it. If yours sounds good on 10 by all means put it there!
I use 2x12's so I rightly cant say about anything else.Out of curiosity talking about too much volume , if you use more speaker cabs could that offset the mush /yuck tone of going to 10 ? Or is it the same effect except with the sound coming out of more cabs and speakers . I hope my question makes sense ?
Thanks for the info. Pushing more air is always good .I noticed that by adding my second 4x12 I could push the amp a little harder. It seems like the extra speakers move a lot more air though.
Part of the process , but to my ears nothing beats the V30'sI had to go through that rough break in period for the V30s though.
I use a Suhr Reactive Load IR with my 1990 Jubilee 2555. My Suhr is rated at 100 Watts. I push the amp with Xotic OD's and generally run the master volume at "7" when recording. For me, that is the sweet spot on the Jubilee and I've had no issues with the Suhr or the amp.
