Restored Coffin Logo 4x12 Cabinet
Discussion in 'Cabinets & Speakers' started by pleximaster, Jun 16, 2020.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,663
    1,948
    I restored this old 4x12 cabinet. Had had some rubbers-is covering glued ontop of the old rexin. Had to remove it all with heat gun.
    • 3 orignal alnicos T0652 (1963) and one earlier B025 all with old H1777 cones.
    • It was wired like this I don't know fig its original or not.
    • Original gold fascia t strip pieced together and re installed
    • Leather straps newer
    • Feet were later additions in plastic but work.
    • Mostly original screws.
    • Made of Khaya/Mahogany aka Gaboon
    • The foam - I have the original it came of easy, but I could not glue it back on as it deteriorated so foam is made of an old 70 mattress... :)
    • Old Logo
    • Repaired old Vynair grill cloth
    • IMG_7111.jpg IMG_7112.jpg IMG_7113.jpg IMG_7114.jpg IMG_7120.jpg IMG_7121.jpg IMG_7123.jpg IMG_7215.jpg IMG_7217.jpg IMG_7218.jpg
    Dogs of Doom and CoyotesGator like this.
  2. pleximaster
    Feb 6, 2012
    1,663
    1,948
    IMG_7218.jpg IMG_7219.jpg IMG_7222.jpg IMG_7223.jpg IMG_7224.jpg IMG_7227.jpg IMG_7229.jpg IMG_7230.jpg IMG_7228.jpg Here are some more pictures...
    plexi
    FogDweller, Kelia, Adieu and 14 others like this.
  3. CptZar
    CptZar Member
    Mar 30, 2019
    66
    53
    Killer cab. Absolutely stunning. With the original Vynair one of a kind.
    Kelia and pleximaster like this.
  4. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,726
    2,313
    Oregon
    Very nice job :) I did the same, but didn't have original Vynair.
    I used the white repro pinstripe. A piece of history!
  5. BygoneTones
    BygoneTones Well-Known Member
    Aug 27, 2013
    1,311
    891
    Superb. You have the matching head to go with it?
    I see the little gabon sticker on the wood there, is that original?
  6. pleximaster
    Feb 6, 2012
    1,663
    1,948
    yes sticker is original but I found it behind the foam
    Put on the baffle so it could be seen, not really 100% historical correct but I think it better to show it
    I didn’t want to accidentally over glue it when I put in the foam
    plexi
    Kelia likes this.
  7. pleximaster
    Feb 6, 2012
    1,663
    1,948
    Here is a pic of the sticker
    Occasionally these stickers are found on the plywood boards that Marshall made the cabs of. One can also find these on other products made of Gabon plywood as Cupboards, doors and furniture from the 50´s and 60´s.
    As I wrote above I found this sticker originally behind the foam on one of the sides but put it in the baffle to show it off... ;)
    soundboy57, Kelia, StingRay85 and 4 others like this.
  8. pleximaster
    Feb 6, 2012
    1,663
    1,948
    83367450_1532786483566626_1507836516233902186_o.jpg 103408328_1532786673566607_7226087310573927872_o.jpg 104250776_1532722453573029_334967219922775019_o.jpg 104369036_1532787066899901_2932755430190676103_o.jpg 104439854_1532722243573050_8238165708101077195_o.jpg 104669386_1532787663566508_1029934286238686873_o.jpg 103403196_1532787770233164_7556500126460081844_o-1.jpg
    Kelia likes this.
  9. pleximaster
    Feb 6, 2012
    1,663
    1,948
    Jan Z found these links showing the stickers used on other items...
    https://roomwithnoview.blogspot.com...BnbKQXH2zzwqWRoK4jqSsZFKXTufHa-2_3uY8Q9J-f1r8
    https://www.bukowskis.com/en/lots/9...CzL53z10kMAJjU6UHH8Y7XEL8m3DIDbjzHl98IycfoC9Q
    Here is a pic of another Gabon sticker inside a another cabinet that was unfortunately cut for side handles and painted with some ugly stuff.
    I believe the stickers were just put on the mahogany plywood boards (By the plywood manufacturer "CFG" and sometimes ended up being inside the cabinet. The pic here shows that the sticker was on before the rim to hold the baffle as part of it is covered by the rim.
    ByGoneTone Brian might be able to shed some more light on this.
    plexi
    ljs, CoyotesGator and Dogs of Doom like this.
  10. shakti
    shakti Active Member
    Jul 14, 2016
    185
    162
    Beautiful work, kudos for the restoration and for sharing your findings!
    pleximaster likes this.
  11. BygoneTones
    Aug 27, 2013
    1,311
    891
    Not much more to add. That hacked up cab was one I got very lucky with about ten years ago on ebay, took a bit of a punt on it not even sure if it was a Marshall at the time. Sold it way too cheaply compared with what they are worth now, but it was in fairly rough condition. Not a lot you can do when the sides are hacked up like that.
  12. neikeel
    4,861
    3,255
    Excellent work!
    What vinyl did you use?
    Is that gold trim in the piping slots original and the same stuff used on the front strip of the 64-65 heads?
  13. pleximaster
    Feb 6, 2012
    1,663
    1,948
    Yes I know you did! I followed that tread when you did that a few years back. It inspired me! :)
    Do you still have that cab or did you sell it? I need more ;) Tom Hinson still have one more old cabinet like these than I do, and the one with most gear when he dies wins! ;)
    Haha! :)
    plexi
    CoyotesGator likes this.
  14. pleximaster
    Feb 6, 2012
    1,663
    1,948
    I was waiting for some Rexin Tom Hinson sent me, that he got from Ray Z, but it got lost in the mail in these Corona times. I found this in a local shop...
    plexi
  15. pleximaster
    Feb 6, 2012
    1,663
    1,948
    But you have had some other cabs with these stickers right?
    I have seen two others with these stickers.
    They were definitely not put on by Marshall in my opinion but by the plywood manufacturer of the boards and sometimes these stickers ended up inside the cab and were therefore preserved. (If the sticker ended up on the outside which was to be covered with rexin/vinyl ot would probably have been removed...
    plexi
    neikeel likes this.
  16. pleximaster
    Feb 6, 2012
    1,663
    1,948
    I missed to answer this
    yes it’s the old t facia strip gold trim
    and is the same as on split front amps
    plexi
  17. Amadeus91
    Amadeus91 Well-Known Member
    Apr 9, 2019
    178
    252
    Once again pleximaster, extraordinary work.
  18. pleximaster
    Feb 6, 2012
    1,663
    1,948
    Here it is again with a matching early offset head (This is not my offset but an amp I got in to restore for a guy in France, member of the JTM Club. Real cool amp. will post pics of that in a separate thread in the vintage section later.)
    pleximaster
    Kelia, J Saw, ljs and 3 others like this.
  19. BygoneTones
    Aug 27, 2013
    1,311
    891
    I know of another one, but didn't own it myself. It was bought by ampaholics. An early 1965 slant, block logo. Possibly this cab.
    The seller made a website and put loads of pictures of it up showing the insides etc, but he took it down once it had sold, and I didn't save the photos :( This was maybe 10 years ago or so.
    Kelia and Dogs of Doom like this.
  20. pleximaster
    Feb 6, 2012
    1,663
    1,948
    Inside of that cab... I think this is the same cab 103309092_1526136554231619_914885786724213123_o.jpg
    And Tom Hinson have a few....
    and here is another 52605467_1150333631811915_6481937275591589888_o.jpg 52769427_1150333575145254_1668565936610738176_o.jpg 52890035_1150333588478586_872359204151623680_o.jpg
