LoudStroud
- Joined
- Sep 22, 2020
- Messages
- 120
- Reaction score
- 218
The other thing to check is the AC voltage out of your wall. That '67 Plexi will likely want to see 115 VAC tops. Wall voltages these days can be 123-126 VAC. If the power transformer in your Plexi has a high voltage on the secondary side, which is very likely, it can smoke new production tubes if running the amp off of a hotter AC wall power. EHX brand EL34's cannot handle higher plate voltages and current. JJ's can handle the higher voltages.
'70's 100 watt Marshall's had a secondary plate voltage around 475 VDC. Plexi era around 520, some as high as 600 VDC!
Your tech can check it by measuring the filament voltage with the amp on a Variac. When the filament voltage sits at 6.3 VAC, the primary AC voltage will likely be around 115 VAC, possibly even 110 VAC. If your wall AC voltage is much higher, get a step down transformer like the BrownBox, specifically designed for this purpose.
