Recommend locking tuners for a Les Paul
Discussion in 'Guitars' started by Macro, Nov 26, 2015.
  1. Macro
    Macro Well-Known Member
    Jul 10, 2011
    2,549
    2,041
    The land of cheesesteaks and soft pretzels
    I have a studio from a few years ago....love everything about the guitar EXCEPT the cheap Grover tuners. Thing hasnt stayed in tune effectively since the day i bought it. I want to replace them with quality locking tuners...want something that will fit in the stock routes...not really interested in modifying the headstock.
    Ideas?
  2. Micky
    Apr 29, 2010
    20,982
    17,568
    Vermont
    I put some Gotoh auto-locking tuners on my Studio.
    Black ones to match the finish. Got them from a member here...
  3. DirtySteve
    DirtySteve Well-Known Member VIP Member
    May 25, 2010
    14,805
    13,409
    High & dry in TN
    I put Sperzels on one of my guitars once, but after further research I wish I'd tried the Schallers instead. I really didn't like the sperzels all that much, I had strings break at the peg and I don't normally break strings...ever! :mad:
  4. Vinsanitizer
    Vinsanitizer Forum Support Spc. VIP Member
    Oct 19, 2012
    27,244
    20,375
    What have I owned, maybe 10 or 12 Les Pauls by now? I currently own 3 Les Pauls and a Hummingbird acoustic, all with stock tuners. I've never had a problem keeping a Les Paul in tune with the stock tuners.
  5. Macro
    Jul 10, 2011
    2,549
    2,041
    wish that were my reality...once the guitar is in tune, it does ok while im playing...but when i put it back down for any length of time all the strings go a little flat, and specifically, the tuner on the G string is flakey...also dont like how sensitive the tuners are....ratio is such that a hairs touch send the string too sharp or too flat. id love something that was better quality, more stable, and a ratio that lends to more fine tuning
  6. DirtySteve
    May 25, 2010
    14,805
    13,409
    High & dry in TN
    Oops, didn't read the question good enough, I just went with the locking tuners part. If you're LP isn't staying in tune it's probably about 99.9% chance it's your nut...not the tuners. just for ****s and grins, put some graphite in the slots and see if it doesn't help. That'll prove it one way or the other.
  7. jensvonbustenskjol
    Feb 5, 2012
    625
    242
    Norway
    I would upgrade to grover locking tuners. Then you don't need modifications
  8. Oldpunk
    Oldpunk Well-Known Member
    May 8, 2015
    563
    392
    So Cal
    It's my belief that locking tuners are tone zappers. There's just a few millimeters of string contact with them as opposed to standard tuners that have a few centimeters. More wraps, a larger surface string contact area, equals more vibration displaced down the pegs to the headstock.
    That being said although I'm not a fan, as a tech I would recommend schallers or grovers for a little less dough.
  9. LedZeppelinFan
    LedZeppelinFan New Member
    Jan 24, 2015
    821
    463
    Grover's Locking Rotomatics, unless you use strings with a low E of .54 or higher... I have a guitar with a set of them, and I rarely have to tune. They are easy to install, don't cost much, don't look particularly out of place on a Les Paul, and make life easier for everyone.
  10. rick16v
    rick16v Well-Known Member
    Mar 13, 2014
    3,013
    2,262
    Swindon, UK
    Less vibration transferred means livelier string vibration and a broader frequency range for the pups (ie less damping). Just saying.
  11. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,633
    4,193
    Austin TX
    I agree tuning issues are not likely the tuners, the nut is much more likely the issue. Some good lube should help but it may need some adjustment. That said, I do like good quality locking tuners.
    You can put as many wraps as you want on a locking tuner, I generally go for 1 good wrap. Sperzels are probably my favorite. I have noticed a tone difference from changing from sheet metal tuners to cast locking ones. The cast tuners sound more solid and fat, the vintage style sounded a little thinner. I was actually a bit surprised to hear a tone difference but think about how flimsy those sheet metal tuners with plastic buttons are - it kinda makes sense. I suspect it is more about the mass and solid connection to headstock than the locking part but that's speculation, it was a very noticeable difference when I changed them on my LP Special:
  12. Macro
    Jul 10, 2011
    2,549
    2,041
    I appreciate all the feedback....I think I'll change the strings first, put some graphite on the nut, and make sure the tuning machines are all snug and lubed. Will give that a test drive for a few weeks and issue a verdict.
    I still like the idea of a lower ratio, but for now, I'd be happy with some stability and smooth tuning.
