StingRay85
- Joined
- Aug 18, 2019
- Messages
- 2,094
- Reaction score
- 1,807
Decided to build a board of the simplest type of pedal, Dallas Rangemaster treble booster. Main reason is learn how to work with my oscilloscope, second reason is that I found an OC44 in my stash of Ge transistors and third because it's a bit easier than a fuzz face.
https://www.electrosmash.com/dallas-rangemaster
The interesting bit about this design is that it mostly seems to effect one side of the wave. So I guess that means the phase is of importance.
Now how will this work with a 2204? The high gain channel is also affecting mainly one side of the wave, first in V1B (cold clipper), followed by V2A which is biased in a way to keep the other side of the wave clean. So in a 2204, depending on the side of the wave you want to further distort, you need to chose between high input and low input, since these two are opposite phase?
What should be the preferred strategy to make this sound the best? I wouldn't be surprised that phase or out-of-phase makes the thing sound either good or simply horrible. I can think of scenarios that more attenuation between V1A and V1B is needed in case the high gain channel must be used for it to sound best, IIRC even with preamp volume extremely low, distortion starts even at low input levels.
