Quick 900 Dr Question
Discussion in 'Marshall Amps' started by BrentD, Sep 16, 2017.
  1. BrentD
    BrentD Active Member
    Jan 27, 2012
    594
    246
    I just picked up a 900 DR off of craigslist. The reverb doesn't seem to be working but I don't have a footswitch attached. Is the reverb defaulted to "off" without a footswitch, or should I be investigating a problem?
  2. Zaphod Beeblebrox
    Zaphod Beeblebrox New Member
    Sep 14, 2017
    On mine - a '95 50 watter - it's default is "on" without the footswitch attached. I'm not 100% sure but I think the reverb shares a valve (the middle ECC83) with the effects loop. Have you tried that? It could be a broken spring or dodgy tank connection somewhere, or something else entirely but good luck!
  3. BrentD
    Jan 27, 2012
    594
    246
    Thanks. I'll check that out.
  4. gjohnson
    gjohnson Well-Known Member
    Oct 16, 2010
    995
    580
    Denver CO
    Might just be unplugged. Take the back off and youll see.
  5. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,265
    1,047
    Saginaw MI
    Reverb is OP-Amp driven....not tube.
  6. RobS
    RobS Well-Known Member
    Apr 19, 2009
    1,033
    351
    Melbourne - Australia
    the wires soldered to the springs in the tank get a fair hammering when the amp is moved about as the spring is very free moving
    Check those little wires as they have a tendency to break off at the solder joint. you will have to remove the reverb tank to do this and whilst there flip it around so the plugs are easily accessed !
    also, check the V2 12ax7 and the leads as mentioned by previous two posts
  7. ricksconnected
    Sep 29, 2015
    13,388
    6,703
    everywhere you wanna be.
  8. Söulcaster
    Söulcaster Well-Known Member VIP Member
    Oct 14, 2011
    9,189
    8,869
    Great Southern Land
    Grab a foot switch and try it out. I no longer have a DR, but I used an aftermarket foot switch for channel switching and reverb. Essential if you're using the B channel for solos.
    Peace
    ricksconnected likes this.
  9. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,671
    4,190
    C-137
    Yeah, but the signal still has to travel through v2b to get on out of the circuit.... along with the rest of the preamp signal.
    So as long as there is a guitar sound, it's all working.
    Usually disconnected cables or bad tank.
  10. BrentD
    Jan 27, 2012
    594
    246
    It's working now. I think it was just oxidation on the jacks on the tank. Thanks for the input - I know the usual culprits in Fenders but I didn't want to chase those gremlins if the footswitch was the simple answer!
  11. John BNY
    John BNY Well-Known Member Silver Supporting Member
    Jul 13, 2013
    2,105
    3,364
    New York
    My JCM 900 had issues with reverb also. It would start to work after the amp warmed up a bit. I replaced the tank and it works great now.
