Question for fellow 2204 owners
Discussion in 'Marshall Amps' started by 67mike, Jul 26, 2020.
  1. 67mike
    67mike Well-Known Member
    Mar 5, 2015
    700
    703
    Just wondering if your 2204 has ghost notes at very low volume ie/0.5....but sounds great/as expected with some volume ie/over 1
  2. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    1,040
    1,061
    No ghost notes on mine but a tiny bit of high note splitted fizz when leading and this is probably due to the bright cap .
    Someone here mentioned that he puts UF5408 diodes in every amps he opens and the top fizz is less and the amp feels softer , might try this .
    Edit ..... @wakjob said this
    67mike and coolidge56 like this.
  3. pedecamp
    14,842
    12,004
    Nope. Its probably your guitar.
  4. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    865
    1,863
    WA state hinterlands
    Ghost note free here. I do have a .001 film cap that slams the input jack shield directly to ground to obliterate local radio station interference. An Aiken Amps trick.
    scozz, 67mike and Kelia like this.
  5. GT08
    GT08 Active Member
    May 31, 2016
    328
    233
    When people only quote numbers to name/describe an Amp, well I'm pretty much fcuked.
    Rock n' roll
  6. Far Rider
    Far Rider Hendrixian VIP Member
    Apr 11, 2011
    7,037
    8,328
    Delaware
    Marshall JCM 800
    67mike and Mitchell Pearrow like this.
  7. South Park
    2,629
    2,113
    So let’s ad to the confusion . A weak filter caps on the power supply can cause this . frequency’s With a log of 60 can ring out with the power supply ripple . You can change out the bias caps and lower the pick ups hope that helps
    SG-Rocker and 67mike like this.
  8. GT08
    GT08 Active Member
    May 31, 2016
    328
    233
    Then why not just say JCM 800?
    50 watt 100w?
    Combo...Head?
    Plus a number if required?
    Rock n' roll
  9. coolidge56
    Jan 30, 2019
    865
    1,863
    Because there's a dozen or more different model JCM800's. That's like saying Ford truck vs Ford F150, 250, 350, etc.
  10. GT08
    GT08 Active Member
    May 31, 2016
    328
    233
    Then just say what it is........we should not have to research to find out!
    Rock n' roll
  11. 67mike
    Mar 5, 2015
    700
    703
    If you do not know what a 2203 or 2204 is. Well, I will leave it at that.
  12. pedecamp
    14,842
    12,004
    Google is your friend.
    FogDweller, Trelwheen and 67mike like this.
  13. 67mike
    Mar 5, 2015
    700
    703
    My amp is a 1986 totally stock with original tubes (except v1).
    I dont want to do caps if i dont require them, i am not in the replace every 10 year fan club.....the stubby f&t look like ass imho......lol
    Sounds glorious turned up.
  14. GT08
    GT08 Active Member
    May 31, 2016
    328
    233
    As I said, you should not have to google to find out.
    So YOU have a JCM 800 and know it....but can you play it and even SOUND GOOD?
    You can SOUND GREAT on a cheap DSL, or even a MG DFX.
    Rock n' roll
  15. 67mike
    Mar 5, 2015
    700
    703
    You made my ignore list. Get a grip buddy....you remind me of this crazy guy who posted here before....name rhymed with crayon77
    FogDweller, kuli, scozz and 1 other person like this.
  16. GT08
    GT08 Active Member
    May 31, 2016
    328
    233
    As you have now resorted to 'name calling', I think most of us know your argument has lost!
    Rock n' roll
  17. Far Rider
    Apr 11, 2011
    7,037
    8,328
    Delaware
    Things haven't changed around here much. :facepalm:
  18. Matthews Guitars
    2,219
    3,057
    Has it ever been recapped? Depending on its usage pattern, those caps may be due for replacement.
    Feel free to post a chassis photo showing the capacitors clearly. There are some definite visible telltales when the caps are very much due for replacement. The shrink wrapped label shrinks too far. Easy to see it once you know what to look for.
    South Park and 67mike like this.
  19. 67mike
    Mar 5, 2015
    700
    703
    Not sure how to post pics
  20. Jethro Rocker
    8,299
    9,866
    If one said a JCM800 50 watt head, that also encompasses a split channel version. How to tell the difference? Model number.
    2204 is very accurate amd beats " JCM800 single channel, 50 watt head". That is frankly a ridiculous way to do it.
    EDIT - I own a JCM 800 too. A single channel 50 watt, 1x 12 combo. Or, I own a 4010. Look it up.
    You play a Silver Jubilee, don't you?
    Which one?
    I think it is completely acceptable on a Marshall amp forum to use model numbers. At some point one recognizes some model numbers.
    FogDweller, joe_cpwe, kuli and 4 others like this.
