Prs Custom 24 setup
Discussion in 'Guitars' started by em07189, Jul 12, 2020.
  1. em07189
    em07189 Active Member
    Jul 14, 2015
    125
    46
    Hello everyone!
    After make a truss rod adjustment and string height adjustment, the action of this guitar at the 12 fret is very dificult to lower, no matter what i tryed until now, the action is still high at 12 and above frets, and if i try to lower the action the buzz starts to happear, what else should tryed here? Is this a normal thing in a prs custom 24?
    Without the possibility to lower a bit the string action in the higher frets its a little bit dificult to me to play this guitar.
  2. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    836
    766
    How did you set the truss rod? To some "recommended" amount of relief?
    Some necks play better straight, some play better with a little relief, some need more relief than seems right. (It's not just a matter of fretboard radius -- some high radius boards need a lot of relief.)
    If you're getting buzzes at the low frets when trying to get lower action at the high frets, try loosening the truss rod for more relief.
    Also, check for high frets or worn frets.
  3. em07189
    Jul 14, 2015
    125
    46
    Yes around 0.007" of relief at the 8 fret
  4. South Park
    2,907
    2,407
    Your neck might be twisted . Is it a bolt on . Have you leveled the frets
  5. em07189
    Jul 14, 2015
    125
    46
    I doesnt seem to me twisted. its a glued set neck, and i didnt leveled the frets.
    tThe height of the strings at 12 fret are the lowest possible, without over buzzing, i dont know how can the action be improved with the neck relief near the recommended values.
  6. RLW59
    Nov 30, 2017
    836
    766
    Where are the buzzes happening? All over the neck? At particular frets? More down toward the nut, or more up closer to the body?
    Again, try it with more relief. And try it with less relief. Individual necks vary.
  7. em07189
    Jul 14, 2015
    125
    46
    Ok, with a little more relief i was able to put the height of the 6 string a little above 1,5mm and the first string at 1,25 mm.
