PPIMV with NFB Control.
Discussion in 'Marshall Amps' started by gregr, Aug 8, 2021.
  1. gregr
    gregr Well-Known Member
    Jul 30, 2014
    495
    516
    Is anyone rocking these two controls and how do you like it?
  2. Stephen H
    Stephen H Member
    Jun 21, 2021
    39
    33
    Nimbin
    I have a ppimv but no nfb control other than a soldering iron, and I don't know what type of ppimv Mr. Friedman is talking about in your sig., but my type 2 (dual 1M with 1.8M r's) does not change anything noticeably to my ears, at least down to half, I've never needed to try it lower.
  3. Stephen H
    Stephen H Member
    Jun 21, 2021
    39
    33
    Nimbin
    Thinking about it, I didn't use shielded cable for mine, and I'm guessing, (and if anyone knows better, please chime in) that using shielded cable would have a kind of variable roll-off via the capacitance of the cable and resistance of the pot/s, so without the shielded cable there would be less/no high frequency attenuation (?)
  4. gregr
    Jul 30, 2014
    495
    516
    I appreciate the replies.
    So I don’t have much experience. The sig is just an appeal to authority.
    I noticed a major difference changing the PPIMV on my Vintage Modern over to a traditional MV. I made other significant changes as well, most of them incremental, but I’m pretty sure the MV was done by itself. The Vintage Modern sounded pretty terrible with the volume below 4 and it seems like a lot of people are using attenuators with them.
    The amp still sounds best loud, but now I can just crack the volume and the amp still sounds pretty good.
  5. Emiel
    Emiel Member
    Jul 22, 2008
    39
    34
    Some PPIMVs work better at low volumes than others. Part of the reason why I finally got a Plexi clone is because the Rich II mod PPIMV works so well. I don't hear any significant tonal changes when I turn it way down. Really impressive.
    matttornado likes this.
