Pool! Dsl40c Bassier Warmer Sound
DSL40c. Wich combination has the bassier sound?
  • Vintage 30
    Votes: 0 0.0%
  • Greenback
    Votes: 0 0.0%
  • Eminence Cannabis Rex
    Votes: 0 0.0%
  • Eminence Legend Series
    Votes: 0 0.0%
  • Eminence Texas Heat
    Votes: 0 0.0%
  • WGS Veteran 30
    Votes: 0 0.0%
  • WGS Retro 30
    Votes: 0 0.0%
  • Total voters
    8
rockstar.md
So that it is. Wich combination has better bass and warmer sound?. I like the fat Marshall tone, so wich of these can make it? Thanks
Micky
VIP Member
Vermont
Why limit your chouces to Celestion?
Why not Eminence or WGS?
Jethro Rocker
Couldn't really say. Haven't had the opportunity to load alllll of said speakers in mine. ;)
BTW you can get a fat warmer sound from the 40C with speaker break in, I have a V30. NOS pre amp tubes, different bias, EQ settings, C19 clip, all contribute. You don't need to change the speaker necessarily although many do.
StoneD
The green crunch channel can be dialed in warm and fat as is. Boost it if you need more gain.
i had wgs et65 in mine though..
John BNY
Silver Supporting Member
New York
I don't own a DSL 40C, but the WGS ET65 produces warm tones.
microhead
KINtucky
Eq
Fat is in the low mids
Warm is in the center
Don't be afraid to cut limited eq's (like a 3 or 2 knob eq section) and turn volume up. Sometimes cutting the highs and lows and boosting overall volume is as good as boosting mids.
