Pick Sharpening
Discussion in 'The Tone Zone' started by Gianni, Apr 6, 2016.
  1. Gianni
    Gianni Well-Known Member
    Sep 13, 2014
    2,647
    3,676
    Greece
    So, you have a bunch of Standard picks, the size of which you’re comfortable with, but would rather they had a sharper, Jazz III-like tip and attack, for speed and precision playing. Well, a little friction can work wonders! :thumb:
  2. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    Pick-sharpening is clearly not this guy’s only skill! :yesway:
    MonstersOfTheMidway and jmp45 like this.
  3. Frodebro
    Frodebro Well-Known Member
    May 14, 2014
    4,473
    5,723
    Seattle
    I use Ultex Jazz III Ultras. They already have the sharp tip on them.
  4. clutch71
    clutch71 Well-Known Member
    Sep 26, 2007
    1,658
    1,157
    Columbus, Ohio
    I watched this the other day and tried last night....works great on rounded off picks that I would normally throw away. I'll buy less picks now!
    Gianni likes this.
  5. rick16v
    rick16v Well-Known Member
    Mar 13, 2014
    3,069
    2,342
    Swindon, UK
    This is bizarrely a really good tip (no pun intended).
    I have refurbished loads of worn picks.
    :rock:
    Mosher Zone and Gianni like this.
  6. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,413
    3,739
    C-137
    Carpet or pant leg. Always sharpen my picks.
    Thinking of trying Chicken Picks.
    Gianni likes this.
  7. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    I’m very glad you found this useful! :yesway:
    I felt rather stupid when I tried it myself, but was quite amazed at the results! :D
    rick16v likes this.
  8. rick16v
    Mar 13, 2014
    3,069
    2,342
    Swindon, UK
    Same here!
    Gianni likes this.
  9. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    Looking at their prices, I sure hope carpet-sharpening works on them too! ;)
    http://www.chickenpicks.com/webstore/
  10. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    Rather than sharing it in a new thread, and since I’m the one who started this one, ;) here’s what you can do to make sure your pick always stays in place:
    I only do the drilling part myself (three 3mm holes in my 1.5mm Tortex Jazz III picks), as I like to still be able to easily move and ‘hide’ the pick when I need to use my fingers, and have not dropped one since I started doing it. :yesway:
  11. ricksconnected
    Sep 29, 2015
    13,388
    6,663
    everywhere you wanna be.
    been doing the carpet trick for decades now. works great.
    also, I use to be a diehard tortex fan. I would use a Heavy Grade
    emory board to rough up the picks for grip. this works wonders too.
    done in seconds no drill needed. ;)
    Gianni and mcblink like this.
  12. Dmann
    Dmann Well-Known Member
    Dec 28, 2008
    2,022
    1,998
    Calgary, Canada
    I took a trip to Walmart and bought a 10 pack of Revlon nail files. A year later, hundreds of picks sharpened and only used one file lol.
    Never need to use the carpet again lol... ( I did for 20+ years ha!)
    Gianni likes this.
  13. MemphisMarshallMan
    MemphisMarshallMan Active Member
    Nov 8, 2014
    253
    225
    I have always used a flat metal file I got from the hardware store to sharpen my rounded off picks.
    Gianni likes this.
  14. slide222
    slide222 Well-Known Member
    Apr 5, 2013
    2,630
    1,733
    cambridgeshire uk
    I use those bendy nail files , and go steady and gentle
    Gianni likes this.
  15. tone seaker
    tone seaker Well-Known Member
    Jan 20, 2011
    3,093
    3,446
    Where the Rock Rolls Hard and the Blues Rains Down
    I dont like the tone the Jazz III's give
  16. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    It takes three swipes on the carpet to give a Standard Tortex pick a Jazz III tip. One swipe will give your old picks the tip they had when you bought them. :yesway:
    ricksconnected likes this.
  17. SmokeyDopey
    Mar 9, 2011
    11,518
    7,211
    Argentina
    I re-use old, rusted strings... but I've never sharpened a pick. I'll have to try that. Thanks!
    Gianni likes this.
  18. jmp45
    jmp45 Well-Known Member
    May 5, 2016
    2,639
    3,954
    At Home
    I'm going to reform my old habits of using a well worn out pick and attempt to reaclimate to one of those pointy things. Carpet trick is interesting. I'll give that a try too. I don't think my go to pick is salvageable though for that mod. I'll keep that around though in case I fall off the wagon.
    Gianni likes this.
  19. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    I HAVE actually tried this myself, but it takes forever in comparison, and the edges never really get as smooth as with the carpet. Actually, I don’t even use the carpet any more. I use a doormat I keep on my workbench to lay my guitars on, so as not to have to kneel down to do it. :yesway:
    There’s just no way I’m ever going back to this, at 2:06: ;)
    Dmann likes this.
  20. Dmann
    Dec 28, 2008
    2,022
    1,998
    Calgary, Canada
    LOL that guy is doing it all wrong (IMO). And yea I use the same Compact Emery Boards.
    I go length wise, 2 passes on the coarse side, and then 1 pass on the fine side --> My pick of choice --> Dunlop Tortex .60mm's. (the orange ones)
    Basically set the Emery Board down and use it just like you would if you were doing it on carpet. Zip the length of the file up and down on the coarse side, change pick sides, zip up and down again, flip over the Emery Board to the fine grit side, and a single pass to smooth the edge.
    Anyways, whatever works hahaha, this works for me and takes about 10 seconds.
    I have about 100 picks that I've been using for a few years. I sharpen after a couple songs worth of playing.
    Gianni likes this.
