pedal power
Discussion in 'The Tone Zone' started by tone seaker, Jan 31, 2021.
whichd do you use thks
  1. Alkaline battern
    2 vote(s)
    7.1%
  2. Non Alkaline battery
    0 vote(s)
    0.0%
  3. power suppy
    26 vote(s)
    92.9%
  1. tone seaker
    tone seaker Well-Known Member
    Jan 20, 2011
    3,099
    3,459
    Where the Rock Rolls Hard and the Blues Rains Down
    which do you use in older pedals Alkaline or Non alkaline or power supply? and why. they deffintly all sound different thks
  2. Travis398
    Travis398 Well-Known Member
    Dec 7, 2011
    1,217
    1,684
    USA
    Power supply.....I like it easy no unplugging things and no changing batteries or checking batteries or buying batteries.......I think my power supply just paid for itself while I was typing this.
    RCM 800, Frodebro and jimmyjames like this.
  3. Old Punker
    Old Punker Well-Known Member
    Jun 17, 2020
    790
    1,894
    Ontario, Canada
    +1 on power supply. Don't like messing with batteries.
    MarshallDog likes this.
  4. pedecamp
    16,454
    15,110
    No point in batteries...
  5. Vinsanitizer
    Vinsanitizer . Double Platinum Supporting Member VIP Member
    Oct 19, 2012
    29,084
    24,464
    Power supply exclusively.
    I don't know anything detectable about tonal differences except where voltage differences are concerned*, that's just way too anal for me to bother with. (By the way, wasn't it Eric Johnson and/or Steve Vai who started that "battery-tone" rumor in an early 90's magazine interview?). These days I don't see the point in using 9v batteries in any pedal except maybe a tuner, and even that doesn't make sense if every other pedal I use is run with a power supply.
    *Voltage differences: for example, the Fulltone OCD takes a 9v, but claims to sound "better" with an 18v power supply because it can take advantage of higher voltage. Or something like that. Otherwise, it's logic. An example of that being, say, in the case of time-based pedals: they consume a lot of power. So if you stick a brand new alkaline 9v (which actually starts out at about 9.5+ volts) in a delay pedal built to require 9.0v, its effect-ability begins to deteriorate immediately, resulting in poorer and poorer performance. (Or something along these lines, I don't have exact figures). So perhaps when players refer to "tone" where batteries are concerned, it's not so much about frequency response, it's more about how much effect is available at varying voltages. That being the case with alkalines, I would never use non-alkaline batteries (not even for wall clocks really). Also, lithiums are a pointless choice: first, they're the wrong tool for the job, second they're way too expensive. Lithium batteries are better suited for short-term, high drain devices like camera flashes and torch flashlights, etc., as I understand it.
    A constant, reliable voltage seems by far the best choice for powering pedals. You'll get consistent effect output, optimal reliability, less need for tweaking, environmental friendliness, and you'll save yourself the hassle and expense of ripping your pedalboard apart and replacing batteries all the time.
  6. jimmyjames
    jimmyjames Well-Known Member
    Jun 15, 2014
    2,287
    2,866
    West Oz
    Power supplies, got a couple of adjustable voltage ones for treble boosters :yesway:
  7. fitz288
    fitz288 Apprentice Fermi's Paradox Analyst Silver Supporting Member
    Apr 7, 2020
    1,234
    2,559
    Pittsburgh, PA
    Power supply.
    Only have a few pedals, but a power supply with multi adapter costs about the same a 2 pack of 9 volts.
    So why not?
    Vinsanitizer likes this.
  8. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    2,151
    2,204
    My PS have voltage regulation. Changes the tonal ballgame on both distortion and affecting the effect..
  9. yladrd61
    yladrd61 Well-Known Member
    Jun 20, 2010
    1,981
    932
    Tacoma-ish, WA
    9V Alkaline, unless it doesn't have a battery.
  10. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,137
    2,127
    I use a Sanyo eneloop pedal juice which is both I guess ? The pedal train volto is the same sort of concept.
  11. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    2,562
    2,682
    Shakedown Street
    I agree 100% with everything you have written , my problem lies in getting the right set up .
  12. RCM 800
    RCM 800 Well-Known Member
    Dec 20, 2019
    874
    1,755
    The only benefit I can see to using batteries is less possibility of noise being added to the signal chain. Anything else is snake oil.
  13. MarshallDog
    Nov 28, 2010
    15,575
    17,730
    Taintville
    Forget batteries unless you have only one or two pedals!!!
  14. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    962
    1,303
    Iowa
    I have a couple Voodoo Lab Pedal Power 2 Plus units under my board that power all my pedals. The only two I don't use my power supplies on are my Analogman Sunface and Beano Boost pedals. They sound better ran off of batteries. The only thing I don't like is I have to remember to unplug the cable from the input on those when I'm done playing so I don't drain the batteries.
  15. mirrorman
    mirrorman Well-Known Member
    Mar 30, 2014
    1,064
    1,759
    Canada
    Power supply except for my Cry Baby which doesn't have a power supply jack.
    Alkaline battery for it.
  16. C-Grin
    C-Grin Well-Known Member
    Nov 8, 2020
    127
    306
    edge of the Mt. Hood national forest
    Power supply with a Furman pedal board power conditioner.
  17. Vinsanitizer
    Oct 19, 2012
    29,084
    24,464
    What do you mean "getting the right setup"?
    El Gringo likes this.
  18. El Gringo
    Jul 24, 2015
    2,562
    2,682
    Shakedown Street
    Space issue with running the power supply / daisy chain tying them all together . Which I just don't like ergonomics wise with the daisy chain where they are practically on top of one another as in to close to each other and then figure in how I stomp on them .
  19. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    1,059
    2,428
    Voodoo Lab Pedal Power 2 on the board and a Furman PL8C power supply in my rack that's the power source for everything.
    I do have a couple of vintage spec fuzz pedals and treble boosters i use a 9v with if i get them out.
    WellBurnTheSky likes this.
