Parallel capacitors
Discussion in 'The Workbench' started by JM5010, Aug 10, 2020.
  1. JM5010
    JM5010 Active Member
    Nov 11, 2017
    276
    46
    I want to put a 22uf 450V and a 22uf 50V cap in parallel to get 44uf.
    Would this blow anything up? Or lower how much voltage the caps can handle? Want to see how 44uf filtering sounds in my amp’s preamp nodes before i buy anything.
  2. South Park
    2,905
    2,404
    Are We talking filter caps if so scrap the The 50 volt cap . Can you explain more
    thetragichero and JM5010 like this.
  3. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    1,477
    1,507
    house arrest
    The higher voltage will handle the lower voltages, so you really have 2 x 22μF 50V. That is the total voltage capacity without issue. I am not sure about the other technical info, sorry. There should be knowledgeable members here to help.
    JM5010 likes this.
  4. JM5010
    Nov 11, 2017
    276
    46
    Filter caps, yes.
    Here’s what i’m trying to do:
  5. JohnH
    JohnH Well-Known Member
    May 31, 2008
    4,112
    2,068
    Wilton NSW
    Both caps will see the full voltage. If several hundred volts hits a 50V cap it would be safer to be in a different room.
    Dogs of Doom and Micky like this.
  6. South Park
    2,905
    2,404
    I don’t think filter caps ad like other stuff does . all you are doing is filter a filter you are not adding anything like stored power . The fifty volt one might work if you don’t put much load on it . Do some online research hope that helps
  7. South Park
    2,905
    2,404
    I did some research they do add so can Get the number you want . Just get the high voltage ones if using for tubes .
  8. mickeydg5
    mickeydg5 Well-Known Member
    24,894
    11,829
    No.
    If doing so both should be 450V.
  9. william vogel
    william vogel Active Member
    Dec 18, 2016
    250
    208
    Adding a capacitor in parallel sums the capacitance, meaning 2x 22uF = 44uF or a 22uF + a 100uF =122uF. The voltage rating of the capacitor doesn’t change/ improve or degrade. If the circuit maximum voltage is 400 volts or whatever it actually is, the capacitor MUST be rated higher than that voltage and it’s helpful for capacitor life to install a capacitor rated for 20% greater voltage or so. Being that there’s a 22uF @ 450 volts already installed, I would put another 22uF @ 450 volts or 500 volts rating. The 50 volt cap will fail and possibly short circuit or explode and it’s not worth adding it for experiment due to the danger of catastrophic failure.
    Dogs of Doom likes this.
  10. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,579
    1,303
    That sounds more like coupling caps to me. They still need to be 450v. Adding more capacitance will pass more bass frequency, but, maybe you already knew that.
  11. william vogel
    Dec 18, 2016
    250
    208
    A 22uF would be in the power supply section of the preamp as the OP referred to it as a “ node”. A coupling cap won’t be a 22uF.
  12. Chris-in-LA
    Jul 19, 2018
    1,579
    1,303
    Right, I was thinking of the .022uf coupling caps. In my defense, his schematic was drawn to look like coupling caps.
  13. william vogel
    Dec 18, 2016
    250
    208
    No harm. I think the important thing is that he understand that the voltage rating must be maintained in parallel circuits.
    Chris-in-LA likes this.
  14. StingRay85
    StingRay85 Well-Known Member
    Aug 18, 2019
    518
    258
    Why not simply replace with a single 47nF?
    I would only apply these tricks when you want to switch one of them out of the circuit, or when the specific type of cap is hard to find. E.g. parallel 470nF with 220nF mustards to come to the desired 0.68.
