paint problem
Discussion in 'Guitars' started by carlocki, Jun 23, 2012.
  1. carlocki
    carlocki Member
    Jun 8, 2011
    416
    12
    Rieti
    i am asking to a friend about paintings restoration...
  2. anitoli
    9,383
    12,605
    Nitro is porus it allows lots of stuff to pass. My EDS1275 still smells like smoke! (both kinds).
  3. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
    Yes this is true, but I fail make a correlation between you guitar smelling like smoke, and the OP's finish problem.:hmm: Help me out here, what are you onto?
  4. carlocki
    carlocki Member
    Jun 8, 2011
    416
    12
    Rieti
    a liuther told me about white petroil
  5. Reckless_Life
    Reckless_Life Well-Known Member
    Nov 14, 2011
    734
    317
    I got a guitar wall mount by König & Meyer.
    Anyone know if these are ok with nitro finishes??
  6. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
    Search the net for reviews.
  7. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
  8. Maklaca
    Maklaca Well-Known Member
    May 23, 2012
    596
    533
    Wow, after reading this, I went home and checked my guitars. My LP custom has been hanging up and it looks like the binding has some darkening where the hangers rub. Thankfully the paint is black or I would suspect that the paint would have and issue as well.:(
    I have noticed lately that the binding was getting dark there, but never put it together with the hanger. That sucks!!!
    Maybe I'll try the surgical tubing trick. That looks like it would work.
    I sure do learn a lot from this forum though.
    TKOjams likes this.
  9. anitoli
    9,383
    12,605
    The OP stated the finish was lacquer which is porus and supposedly allows the instrument to "breathe". Gibson has used this argument for years to claim why their guitars sounded better. Not only will it absorb odors it will allow lots of thing to pass. Look at the spot on used gibbos where your arm rests across the top of the body. Skin chemicals,acids, sweat, can quickly make a disfigured area on the finish and theres really nothing you can do about it.
    The OP's discoloration started from the bad rubber on the surface of the lacquer ( which had a chemical reaction to the lacquer ) and then went through it. It will absorb stains as well as odors. Any guitar that "yellows" with age is lacquered. Remember lacquer is made from cotton dissolved in nitric and sulfuric acids then liquified with fast drying solvents. Your ax is basically covered in chemically recomposed organic matter and it is quite delicate, and WILL negatively react to different chemicals or substances.
    If you dont want the dissapointment of finish problems such as the kind that occur with lacquer (checking, discoloration, ect) i would strongly reccomend guitars finished in polyester.
  10. IbanezMark
    IbanezMark Senior Member
    May 7, 2009
    3,998
    1,184
    TKO Jams knows his stuff when it comes to finishing. I think he was just prodding a bit :lol:
    TKOjams likes this.
  11. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
    Who, ME?:naughty:
  12. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
    You can have all the plastic coated guitars you want:thumb:
    As for me, I'll finish mine in nitrocellulose lacquer, and I like checking as long as it's natural.
  13. carlocki
    carlocki Member
    Jun 8, 2011
    416
    12
    Rieti
    a liuther sugest me about white petroil...
  14. IbanezMark
    May 7, 2009
    3,998
    1,184
    I'm a frequent lurker at luthiers corner :cool:
  15. Wiseblood
    Wiseblood Well-Known Member
    Jan 20, 2010
    2,907
    1,627
    The Pit
    Do we even know it's a Nitro finish? Jackson's generally use Poly finishes unless it's a custom shop or an older vintage model.
    Make sure you know the finish first before you a apply a solution.
  16. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
    I fugured as much:thumb:
    Next time you're lurkin' say hello.:wave:
    We'll talk Idanez
  17. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
    jackson rr1 standard white
    http://www.marshallforum.com/tone-zone/29056-my-gear.html
  18. anitoli
    9,383
    12,605
    Well dude YOU did ask a question, no?
    So let me ask you one then, why would a nitro finished guitar retain residual smoke odor while a poly finished guitar used in the same enviroment for an equal ammount of time not have a residual smoke odor?
  19. carlocki
    carlocki Member
    Jun 8, 2011
    416
    12
    Rieti
  20. TKOjams
    TKOjams New Member
    Jan 29, 2012
    77
    61
    Connecicut USA
    You already know the reason why, and it has nothing to do with the reason the OP's guitar is having a reaction with hanger he's using. That's the reason I asked you why you brought it up.
