Origin 50H Solo Volume Lift
Discussion in 'Marshall Amps' started by Martin Adams, Jun 6, 2020.
  1. Martin Adams
    Martin Adams Member
    Apr 25, 2019
    33
    52
    How do you guys get a solo volume lift with your Origin ?
    With the prep amp gain cranked the onboard boost doesn’t do much
    Boost in the FX loop doesn’t seem so boost which I believe is due to the loop and PPIMV ???
    Any ideas ?
  2. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    537
    1,233
    I use my guitar volume but that is true for any amp i use. I set the amp up for a mids forward tone anyway. Another thing is an eq to step on. Accentuate the frequencies needed for you to cut through the band. I find this a lot better than just going for more volume.
    scozz and Mitchell Pearrow like this.
  3. Mitchell Pearrow
    10,616
    18,063
    I think that is the only way to get any lift, my only issue is I can’t play lead ha ha
    nrjdennis1, scozz and Biff Maloy like this.
  4. Martin Adams
    Martin Adams Member
    Apr 25, 2019
    33
    52
    I’ve solved it by turning down the gain and running all my pedals including boost up front. Drive comes from pedals instead and it works well
  5. Maggot Brain
    Dec 13, 2011
    593
    657
    Seattle, Washington
    I have realized not many people seem to utilize the volume knob on the guitar. That for me has always been a given and how Ive always known to play. Seems like a lot of people just play with the guitar's volume maxed then struggle for a volume jump or "boost" when it comes to leads. I dont know but playing like that just seems weird but thats just me.
    Learn to play with the volume rolled back a tad for rhythm etc and adjust the volume knob on the guitar when it comes time to solo or play a lead/melody.
  6. dslman
    dslman Well-Known Member
    Apr 15, 2012
    2,930
    1,391
    See, this makes me wonder if the fx-loop return on the OR50 can be used with stereo pedals , to slave another head for stereo sound.
    Is the fx-loop different from most Marshall heads?
    So a volume pedal in the loop of the OR50 doesn't work?
  7. dslman
    Apr 15, 2012
    2,930
    1,391
  8. scozz
    scozz Well-Known Member
    Jul 20, 2008
    3,401
    7,708
    This is good advice. :cool:
