Origin 50C - Bad Odor
Discussion in 'Marshall Amps' started by Mitey, Sep 2, 2020.
  1. shredless
    shredless Well-Known Member
    Sep 15, 2010
    5,141
    3,510
    Lies! No one kicks a lil tuna out in the middle of the night
    MarshallDog and Mitchell Pearrow like this.
  2. vtrain
    vtrain Well-Known Member
    May 15, 2020
    201
    339
    Chicagoland
    I've had two Origins, the 5 that I sold, and the 20 combo that I still have, and neither had any smell, aside from the "new amp" smell that goes away quickly, and isn't at all what I'd describe as bad.
    Mitey and Mitchell Pearrow like this.
  3. steveb63
    steveb63 Well-Known Member
    Feb 3, 2010
    403
    776
    Az USA
    Yes sir, I am an owner.
    And no, there is no odor from mine, unless you count the stinky clams I play now and then.
  4. Mitey
    Mitey New Member
    Sep 2, 2020
    11
    10
    Same issue, the grill cover wreaks. I'm finding that this amp was just a mistake all the way around. You can't use a gain pedal in the FX loop, didn't know that. When I turn amp on or off the amp it makes a loud "pop" with the FX loop on, even when the FX are all off. The one good thing about it is that you can DI into a recording device without the speaker attached.
  5. Mitey
    Mitey New Member
    Sep 2, 2020
    11
    10
    Does your amp make a "pop" sound when you turn the amp on or off with the FX loop engaged? Mine does whether the FX in the pedalboard are on or off. I also didn't realize that you can't use a distortion or gain pedal through the loop as well.
  6. Mitchell Pearrow
    11,962
    21,498
    Mine as long as volume is turned down to 0 the pop is minimal on start up or shut down, and to use the loop you already know you have to have the footswitch plugged in to activate it, I have always put my dirt pedal into the front of the amp, have never tried it in the loop.
    Good luck, I know the Origin is not for everybody but I am getting along with mine just fine, and it’s far cheaper in cost than a 1987. .
    Cheers
    MarshallDog likes this.
  7. Mitey
    Mitey New Member
    Sep 2, 2020
    11
    10
    I was told by Marshall to turn off the switch before turning off the amp and to never use a gain or distortion pedal in the loop.
  8. Mitchell Pearrow
    11,962
    21,498
    Ok the no gain or distortion in the loop is a first for me.
    Thanks
  9. Sg-ocaster
    Sg-ocaster Well-Known Member
    Jun 1, 2020
    394
    438
    May I suggest Summers Eve???:shrug:
  10. What?
    What? Well-Known Member
    May 17, 2018
    1,001
    914
    Better keep the cats away from it. Your amp might get the cat scratch fever. Then you'll only be able to play Nugent songs through it. Hahhyyy!
  11. MarshallDog
    Nov 28, 2010
    14,558
    15,759
    Taintville
    With all the amps I have bought new or used, none of them had Tolex glue that smelt bad, not one!
    steveb63 and Mitchell Pearrow like this.
  12. MarshallDog
    Nov 28, 2010
    14,558
    15,759
    Taintville
    That’s right its got to be A LOT of tune lol!
    steveb63 and shredless like this.
  13. MarshallDog
    Nov 28, 2010
    14,558
    15,759
    Taintville
    My experiences have been if the amp is loaded with JJ tubes It will pop but when I put in better tubes the pop is gone. My last new amp the Fender 68 Custom Deluxe Reverb did it. I replaced the tubes and its gone now, dont figure!?
  14. Avenger
    Avenger Member
    Aug 28, 2020
    80
    92
    I have received an Origin20c a few days ago and I simply love the smell that comes out when the amp is warm! lol
    It is a very weak smell; have to stick my nose in the grates to feel it, but it's definitely something different than a solid state's... different material cooking in a tube, I guess. Thing gets pretty warm in minutes, can feel the warm airflow out of the top vents!
  15. OriginOfTheSpecies
    OriginOfTheSpecies Member
    Aug 24, 2020
    27
    52
    Mine just smelt new/kind of pleasant. I do remember a housemate many years ago getting a new Marshall practice amp that smelt bloody awful.
    Mitey likes this.
  16. neikeel
    4,735
    3,140
    Sometimes electrical fittings can smell when hot, typically some of the plastic tings that secure lampshades if you use 100w or 60w bulbs.
    Odd that a new amp should do it.
  17. Mitey
    Mitey New Member
    Sep 2, 2020
    11
    10
    These Origin50 combos smell awful. I do like the fact that I can run this into my VS-1880 and not have the amp's speaker connected but the design isn't the best either. I should have just bought the head and the a cabinet later, I doubt that I would ever use it in a live setting.
  18. MarshallDog
    Nov 28, 2010
    14,558
    15,759
    Taintville
    My Origin 50C smells just fine no issues at all!
