Origin 50 as Power Amp for JMP-1
Discussion in 'Marshall Amps' started by mrp, Jun 9, 2021.
Tags:
  1. mrp
    mrp Active Member
    Dec 19, 2016
    130
    81
    Is it a good idea to use an Origin 50 head as a power amp for a JMP-1?
    The rack power amps are insanely expensive. Not much choice either.
    On the other hand, I'm not impressed with the fact that the preamp section will be working idle all the time. No smart biasing like in the DSL40CR either.
    Thanks.
  2. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    2,042
    4,903
    Springfield, Ohio
    Should be fine. I have used heads as power amps with my JMP-1 for decades. I would only add that not all power amp sections will sound the same.
  3. Dogs of Doom
    26,420
    35,153
    &... it's easy to slam the PI w/ the JMP-1, so volume w/ caution...
    Most amp's you lose master volume control, on the head, so, you'll want to make sure to turn down the volume out on the JMP-1.
    mrp, Michael Roe and Mitchell Pearrow like this.
  4. mrp
    mrp Active Member
    Dec 19, 2016
    130
    81
    On Origin, wouldn't both Volume and Presence remain active though?
  5. mrp
    mrp Active Member
    Dec 19, 2016
    130
    81
    BTW does the Origin have a Cathode Follower in the preamp? Makes for a nicer "like a record" sound if using the preamp.
  6. OriginOfTheSpecies
    OriginOfTheSpecies Active Member
    Aug 24, 2020
    137
    224
    One thing I noticed trying to slave my Jet City into my Origin via their effects loops was how much hotter the JC signal was to the "pedal level" the Origin expects. It worked, but required keeping master volume much lower than normal (ie as loud/verge of breakup at 9 o'clock rather than 2). The JMP might be easier to match with it's own master volume in path.
    Mitchell Pearrow and mrp like this.
  7. Dogs of Doom
    26,420
    35,153
    IDK, not all amp's do...
    sorry for the late response, I just happened to see this post.
  8. mrp
    mrp Active Member
    Dec 19, 2016
    130
    81
    No idea on the Cathode Follower, anyone?
