Opinions needed! Good, but cheap OD pedal?
Discussion in 'The Tone Zone' started by Adrian R, Jun 13, 2012.
  1. Adrian R
    Adrian R Well-Known Member Gold Supporting Member
    Jan 28, 2009
    6,865
    5,548
    Far North Chicago Burbs'
    Hi, looking for a low cost, decent OD pedal for a backup....
    MUST have true bypass...meaning you have noted that it actually does...
    Many mfgs. say they do, but they don't, and do color or attenuate your sound when disengaged...
    Please advise...
  2. pedecamp
    17,970
    18,101
    My fav OD so far is a Bad Monkey. Try one it sounds big.
  3. DirtySteve
    DirtySteve Well-Known Member VIP Member
    May 25, 2010
    15,039
    14,222
    High & dry in TN
    That's what I was going to recommend, but the BM isn't true bypass.
  4. bvoris
    bvoris Well-Known Member
    May 4, 2012
    1,583
    1,302
    Houston, Texas
    MXR ZW-44 is pretty decent usually $50 - $60 used
    Joyo Vintage/Ultimate (new) are decent too $40 I just bought a vintage and if your looking for a Tubescreamer TS-9 its pretty close.
  5. diesect20022000
    diesect20022000 In Memorandum VIP Member
    Sep 5, 2010
    19,575
    7,205
    44076
    yeah the BM is awesome but it's not TB and it does subtract a bit of lows (very low amount) when dissegauged.
    i don't know about true bypass but i also like the Ibanez JD9 Jet Drive (even has a mid contour knob:) It's going to be my next OD/booster.
  6. Maklaca
    Maklaca Well-Known Member
    May 23, 2012
    596
    533
    If you have found a pedal you like, but it is not true bypass, there are people who do mods to make them true bypass, or you can even do it yourself.
    Just another option.
    HOT TUBES 70, DirtySteve and bvoris like this.
  7. Lespaulnmarshall
    Lespaulnmarshall Well-Known Member
    Aug 31, 2009
    5,533
    895
    For a ts808 style od try a lovepedal kalamazoo.For a transparent od try a barber ltd.
  8. cruisemates
    cruisemates Active Member
    Dec 16, 2010
    125
    34
    I picked up a Moen Rusher (made in China) and I am astounded at how good it sounds. You must have a power supply )does not batteries) and it works best on a basically clean soubd. But it has tons of sustain and a nice fat tone.
  9. HeHasTheJazzHands
    HeHasTheJazzHands Well-Known Member
    Nov 4, 2011
    8,548
    4,984
    Louisiana
    +1 on the Joyo pedals. :D
  10. Beezerk
    Beezerk New Member
    May 1, 2012
    37
    9
    Northeast England
    Been messing around with a Boss OD-3 recently, nice pedal.
  11. jwebb1970
    jwebb1970 New Member
    Nov 28, 2011
    733
    249
    Visalia, CA
    Or check your local Guitar Center. MXR did a special run of the "Classic Overdrive" (Model can be either the the CL-1 or M66). Produced for GC for an anniversary sale a while back. While currently sold out online, they can still be found in many GC stores.
    It is a Taiwan-assembled pedal that uses the same materials as all US built MXRs. May come in off-white w/ green script or reversed - green w/ off white script.
    The pedal is the same circuit as both the ZW44 & the GT-OD (MXR's Custom Shop Tube Screamer clone). As with the above pedals, the M66 has an internal switch that allows the user - or in the case of MXR, the factory - to determine which pedal it is going to be before slapping the guts in the traditional MXR casing. Throw the switch one way, it is the ZW44, the other way...the GT-OD.
    The ability to flip said switch does involve disassembling the pedal, but there are several examples online (incl. members of this very forum) of folks that have modded the Classic OD to have the switch on the OUTSIDE, allowing instant choice btwn pedal types.
    The best part? You shoud be able to score a new Classic OD in the ballbark of under $50. Not too shabby considering that it is in fact TWO MXR overdrives that each retail for around $100 new. You may also want to check EBAY - I have seen a few used ones there as well. I picked one up for myself last December during my local GC's post-XMAS sale. Paid less than $30 for a new off white one.
  12. bvoris
    May 4, 2012
    1,583
    1,302
    Houston, Texas
    GC in Sugar Land / Houston didn't have one so I got one on ebay for $49.99 :eek:
    Don't tell my wife though she is already on me for having so many overdrive pedals...
  13. Georgiatec
    Apr 23, 2010
    5,824
    5,698
    I got one of these awhile ago really good and great value (£55 in UK). True bypass plus you can change the chip for different tones. :)
    [ame=http://www.youtube.com/watch?v=cxgamjZnZvQ]Akai Pro Drive3 Overdrive Pedal: Overview - YouTube[/ame]
  14. Wycked Lester
    Wycked Lester Well-Known Member
    Apr 21, 2010
    5,105
    2,965
    667 Neighbor of the Beast
    cheap/good overdrive,....first thing that comes to mind is Boss SD-1. $50 I've tried pretty much everything out there, and I keep comming back to the sd-1.
    HOT TUBES 70 likes this.
  15. jvm210guy
    jvm210guy New Member
    Jul 7, 2011
    3,818
    1,677
    Chicago, home of the blues...
  16. HOT TUBES 70
    Oct 13, 2008
    11,284
    5,838
    In my opinion the Boss SD1 is still one of the best Overdrives for the money !
    This one pictured below has had some work done inside and out , and even if you factor in the upgrades , its still alot of tone for the cash !
  17. HOT TUBES 70
    Oct 13, 2008
    11,284
    5,838
  18. zenfly
    zenfly Well-Known Member
    May 6, 2012
    1,064
    701
    CoCoa Bch Fl
    My favorite is my Tone Bone Classic but they're $200 new but I just saw a used one in the case at Sam Ash Orlando for $99.. Pissed me off cuz I paid double.. The thing I like the most is I can set it so if I play light it's almost clean with a little dirt then dig in and get a real nice bite.. It has great post OD tone control too.. but I run a Boss DS1 too set much higher..
    Heres a Hot British...
    http://www.ebay.com/itm/RADIAL-TONE...996?pt=Guitar_Accessories&hash=item4ab89a9794
  19. American Viking
    American Viking Well-Known Member
    Jan 9, 2009
    4,080
    1,245
    RICHMOND, VIRGINIA
    SD-1.
    If the true bypass thing bothers you that much than you can simply make a line/loop selector to bypass the pedal. I've never had any pedal bother me whether it's true bypass or not. I can't hear a difference and I don't think the kid at the back of the bar can either.
    I can show you how to make a line selector pretty easy too.
    buzz likes this.
  20. jwebb1970
    Nov 28, 2011
    733
    249
    Visalia, CA
    No such thing as too many overdrive options.
    I was in my local GC last night - they still have the off white ones her in central CA for $39.99. But an extra $10 is not a huge premium to pay & have it sent right to ya. Enjoy!
