Old Blackface Showman / No Sound Except Knob Crackle
Discussion in 'The Workbench' started by iron broadsword, Apr 20, 2018.
  1. iron broadsword
    Oct 27, 2011
    2,966
    1,445
    It's a '65, I think. Transformer codes are 606551 and 606542. Alright, so last time I fired this thing up it worked fine but it's been sitting for about a year and now it makes no sound when you play through it. It does however give off some volume knob crackle when you rotate those, so I'm assuming the problem is somewhere early on in the preamp. This is all through the normal channel.. in the vibrato channel it seems completely dead (or maybe it's just that that volume knob doesn't have a crackle issue)
    What I've done so far:
    - Tried all the tubes in another amp, and they work fine there
    - Cleaned all jacks (cleaning all pots is next on the todos)
    - Cleaned all tube sockets
    - Tried obvious stuff like different guitar / cables
    It's never had a full cap job.. so yeah I'm thinking it might be time for that but the big electrolytics were replaced 2 years ago. The preamp tubes don't get very warm, and I can hold V3 with my bare hands while the amp is operating so it could be that the heater supply voltage is the issue.
    Where do I go from here? Thanks in advance
  2. iron broadsword
    Oct 27, 2011
    2,966
    1,445
    Checked the preamp heater voltages at pins 4/5, and yep it's about 5mV so that's definitely the problem. Plate voltage was on point though at 469v so the thing isn't completely dead. Going to try to hunt down a schematic, the code stamped on the chassis beside the board is TB 3 66 if anybody's got a schem for it.
  3. chuckharmonjr
    Mar 26, 2010
    8,818
    4,303
    That'll do it every time. Great catch!
  4. iron broadsword
    Oct 27, 2011
    2,966
    1,445
    SS rectifier. Alright, I might even have replacements for those on hand. Gotta find a damn schem before I can mess with it though.. google is being difficult.
  5. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,633
    4,195
    Austin TX
    iron broadsword likes this.
  6. iron broadsword
    Oct 27, 2011
    2,966
    1,445
  7. iron broadsword
    Oct 27, 2011
    2,966
    1,445
    Alright, got some pretty wild readings on the preamp tubes. (Btw my V1-V4 is assuming V1 is furthest away from the power tubes).
    I got 6.3V across green wires at pilot light.
    V1:
    6 - 615mV
    8 - 18.1mV
    1 - 622mV
    V2:
    6 -618mV
    8 - 12mV
    1 - 621mV
    V3:
    6 - 367V
    8 - 33mV
    1 - 373V
    V4:
    6 - 299V
    8 - 73V
    1 - 301V
    I got 2.9V on Pins 4/5 on all 4.
    So V1 and V2 are both clearly not getting enough voltage, V3 is very high on pin 1 and very low on pin 8, and V4 is very high on pins 6 and 1 and a little low on 8. And the heater voltage is very low on all. Wtf.
    Here's the schematic: http://schems.com/schematicheaven.net/manu/fender/showman_ab763_schem.pdf
  8. ampmadscientist
    17,860
    12,068
  9. iron broadsword
    Oct 27, 2011
    2,966
    1,445
    Jesus, I can't find that 4.7k to save my life
  10. iron broadsword
    Oct 27, 2011
    2,966
    1,445
    Alright, so the wire that connects D to the 4.7k had come loose. Fired it up and it's ALIVE again, but there are still some issues. Gonna grab voltages again tomorrow.
  11. ampmadscientist
    17,860
    12,068
    It's under the capacitor cover.
