Noisy Marshall JMC 800 Lead (2203)
Discussion in 'Marshall Amps' started by rbotn, Oct 9, 2020.
Tags:
  1. rbotn
    rbotn New Member
    Jun 17, 2015
    15
    2
    Hi.
    I am repairng guitar amplifiers and I have a problem with a JMC 800 (2203). The owner of the amplifier has short-circuited two pins on an output tube. There is sound at the amplifier, but there is a noise in the pre-amp, mostly at high input. There is no noise when the master volume is turned down. Attach a sound-file with the noise.
  2. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,366
    2,132
    So, what have you checked or replaced up to this point?
  3. Drinkingdeath01
    Drinkingdeath01 Well-Known Member Gold Supporting Member
    Feb 1, 2010
    1,427
    3,745
    Minneapolis Minnesota
    Sounds like every other JCM800 that I've ever owned.
  4. FogDweller
    FogDweller Well-Known Member
    Jun 19, 2014
    196
    388
    Doesn’t sound like any I own.
    Chris-in-LA likes this.
  5. rbotn
    rbotn New Member
    Jun 17, 2015
    15
    2
    I have change both preamp tubes with new one, no result. I sounds like the noise is comming for the high input. When I pull out V1, the first tube, the amp is silence.
    tce63 likes this.
  6. Chris-in-LA
    Jul 19, 2018
    2,366
    2,132
    Both inputs run through v1. Do you have any experience working on amps? Do you have a voltmeter? Have you opened up the amp for a visual inspection?
  7. marshallmellowed
    Jun 26, 2009
    4,457
    6,413
    Try swapping components "C" and "M", should sound perfect!
    StingRay85 likes this.
  8. StingRay85
    StingRay85 Well-Known Member
    Aug 18, 2019
    1,258
    947
    V1 is shared by both inputs. High input uses V1A while low bypasses it. So there's a massive difference in volume right there. Based on the very limited info you gave, it can be a lot of things. Maybe this should be moved to the workbench subforum
  9. JP2036
    JP2036 Well-Known Member
    Aug 7, 2020
    501
    570
    Thats nothing.
    tce63 likes this.
  10. rbotn
    rbotn New Member
    Jun 17, 2015
    15
    2
    Yes I have experience working on amps, but this is a tricky one. There is nothing to see trough visual inscctions. The voltage around V1 and V2 is whitin 10%. The noise is the same with or without cable in the inputs. Are there anybody who have bad experiences with the jack inputs?
    Thanx, I will also post on that forum too.
  11. StingRay85
    Aug 18, 2019
    1,258
    947
    Clean the inputs is for sure where you should start
  12. dro
    dro Well-Known Member
    Aug 1, 2015
    1,060
    1,857
    Blue Springs Mo
    Are you using a Craftsman model 1019 Laboratory edition signature series torque wrench?
  13. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,180
    2,195
    No point in even tackling the job without one in my opinion.
  14. Chris-in-LA
    Jul 19, 2018
    2,366
    2,132
    If the voltages look ok and you see no damage, you might need a scope to track down that noise.
    EADGBE and tce63 like this.
