Noise when jumping channels
Discussion in 'Marshall Amps' started by Mats Raknerud, Jul 16, 2020.
  1. scozz
    Jul 20, 2008
    4,392
    9,956
    I think maybe @Martin Adams has a very good suggestion. Do you have a known good 12AX7 @Mats Raknerud?
    Oh BTW,...:welcome: to The Marshall Forum!!
  2. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    2,448
    2,212
    Las Vegas, NV
    This is incorrect, mostly. Two separate input channels (HIGH TREBLE #1 through one triode and NORMAL #2 through another separate triode) that DO share the same EQ later in the circuit! These two separate input channels get "mixed" together in parallel just after the volume/LOUDNESS pots, yet before another gain stage/cathode follower and then the tone stack.
    If amp is new, I would NOT get it repaired, but instead replaced! There is a defect (possibly two different defects) and I would not depend on some repair tech outside the factory to correct it in a bullet proof manner! I would be absolutely adamant with the retailer about this and demand a refund if they won't take care of the replacement at no cost to you! A NEW amp should function perfectly, right out of the box!
    It would help to know generally where you are located?
    And :welcome: to the forum!
    Just My $.02,
    Gene
  3. Mats Raknerud
    Mats Raknerud Member
    Jul 16, 2020
    22
    28
    Btw. This all seems even worse with humbuckers. With the strat I can move around and find a pretty quiet spot. Not with the Gibson 335. I think the 335 has unwaxed pickups.
    It seems like the strat is almost capable of canceling out the noise if I find the exact right spot. Like it normally would be with a single coil with a fair amount of gain. But yeah, as you can se in the video it's a lot more noise than you would normally get with these settings.
    Also having the output power of the amp dropping I would assume there's something very wrong. The gain stays pretty much the same, so something weird is going on after the preamp.
    tce63 likes this.
  4. Mats Raknerud
    Jul 16, 2020
    22
    28
    Thanks.
    Yes, I have taken one out of another working amp. And swapped the preamp tubes in the Marshall one by one. No change.
    Mitchell Pearrow, scozz and tce63 like this.
  5. Mats Raknerud
    Jul 16, 2020
    22
    28
    Yes, you're absolutely right.
    I've emailed Thomann. I live in Norway. So it will probably get shipped back to them. :)
  6. marshallmellowed
    Jun 26, 2009
    4,260
    5,916
    Do you have anything in the FX loop?
    tce63 likes this.
  7. Mats Raknerud
    Jul 16, 2020
    22
    28
    Brand new.
    Nothing in the loop. Same with the loop bypassed. (bypass switch on the back)
  8. marshallmellowed
    Jun 26, 2009
    4,260
    5,916
    OK, so that eliminates any ground loop possibilities. There seems to be an issue with the input jacks (wiring, contacts...). It's a bummer, but your best bet is to return it for another amp.
  9. WellBurnTheSky
    Mar 23, 2019
    1,004
    2,303
    They're great. My old bass player had an issue with an amp he had purchased, they dispatched an UPS delivery man to collect it the next day. And since they didn't have the exact same amp head available, they offered him a replacement for a higher value.
    I've bought lots from them, and always was super happy with them.
  10. Im247frogs
    Im247frogs Well-Known Member
    Jan 31, 2012
    919
    1,223
    Brooklyn, Joey!
    Now that is difficult to believe. I have a couple home built amps, and a couple built by people who know what they're doing and ALL of my Tele's are noisy as SHIT thru all of them unless they're in humbucking mode. And they're all shielded, shielded output jack wire etc.
  11. tce63
    Aug 6, 2018
    1,955
    5,340
    Sweden
    Thomann are great and will sort it out for you, they arrange pickup and send you a new one :applause::applause::applause:
    I live in Sweden by the way.
    TC
  12. South Park
    3,410
    2,936
    Try a balanced cable you may have a ground loop in the cable
    tce63 likes this.
  13. marshallmellowed
    Jun 26, 2009
    4,260
    5,916
    Not sure what that means, and not possible. The ring of standard patch cables are grounded on both ends. The input jacks are mono, and not designed for balanced cables.
    tce63 and WellBurnTheSky like this.
  14. South Park
    3,410
    2,936
    It is the cable that goes between the head and the cab . It not the same as The guitar cable . Some times the cables can pick crap and send to the grids that might be what it is doing
    tce63 likes this.
  15. Mitchell Pearrow
    12,984
    24,195
    :welcome: To the forum
    I do hope you get your amp issues worked out.
    They are killer amps.
    Cheers
    Mitch
    tce63 likes this.
  16. South Park
    3,410
    2,936
    The way you stop RF is a grid stopper the a 68 k resister on the shielded cable on V1 pin 2 the grid . You might have a oscillation condition . This is a big problem with high gain amps
    tce63 likes this.
  17. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,042
    1,805
    Brand new? With all these issues? Take it back. That volume drop issue seems to suggest that your amp is broken.
  18. WellBurnTheSky
    Mar 23, 2019
    1,004
    2,303
    So it's not balanced cable, it's speaker cable (non-shielded, usually bigger gauge). And if this was the source of his problem, noise would be constant, as he didn't plug/unplug it (and thankfully so).
    And wtf are you talking about, SV20H "high gain amp" ? It's about as remote from that as could be...
    TXOldRedRocker and tce63 like this.
  19. DC135er
    DC135er Member
    Aug 6, 2009
    115
    21
    S. Texas
    Sounds to me like a preamp tube is going bad or is microphonic. Jumping channels shouldn't create any him at all.
  20. Mats Raknerud
    Jul 16, 2020
    22
    28
    Hi guys.
    just wanted to chime in and say that Thoman sent me a new amp and paid for the shipping of both return of the old amp and for sending me the new. :)
    happy days.
    Now if Covid19 could just go away maybe I could get some gigs again.
    tce63 likes this.
