New SV20H Day!
dilver
What you folks said pretty much nails and echos my sentiments exactly! While I've been just barely (and carefully) getting away with no attenuator through my 1965B cabinet, tonite I was just going over a few parts (quietly) with our new drummer (without the bass player) and instead of plugging in the attenuator, I simply turned the guitar volume (on a single coil Strat no less) way down and was amazed at the tones and response! Truly one of the more stellar amps I've ever used, in +55 years of Screechin' & Squawkin' with guitars through tube amps! There be magic in these SV20 amps!
Simply Lovin'
Gene
Glad you’re getting as much enjoyment out of it as I am. If you’ve come this far, you might want to try some different tubes - don’t get me wrong; the stock tubes are fine. But I usually retube most of my amps and do notice a difference. My preference are old RCA 12AX7s, but there are lots of options, depends on what you like. After, trying a few in different positions, I ended up with an RCA long black plate in V1 and short grey plates in V2 AND V3. I left the stock power tubes as I didn’t have any good EL34 on hand, and people seem to say good things about the JJ EL34s. The difference I heard in the V1 tube was that it sounded what I can only describe as more “lush” - less brittle, smoother breakup, richer.
Gene Ballzz
Las Vegas, NV
I will ilkely try rolling some tubes when I finally get a
5 - Round Tuits - Get A Round Tuit - Guard it With Your Life Plus one BONUS  Token.
!:p
I do suspect however that smoothing out that "brittleness" may somewhat compromise tha amps ability to "cut through" a mix at such low volume levels? While I do have a fairly wide variety of 12AX7/ECC83 tubes on hand, none are necessarily "highly revered" and I really don't want to go down that rabbit hole of chasing esoteric, high priced, NOS tubes! I do plan to roll through my stash to find a couple/few units that will keep the amp sounding as close as possible to how it already does (or even a possible improvement), in the inevitable eventuality of a tube failure!
It's kinda interesting that like most times and comparisons, the amp may sound a bit harsh and maybe even a tiny bit lacking in the bottom end, when playing by myself. Then in a full band setting, that harshness perfectly cuts through and the low end gets filled in by the bass and kick drum! I really couldn't ask for a much more perfect amp!
Simply Screechin' & Squawkin'
Gene
colchar
The Great White North
Congrats on the new amp!
I'm curious as to what you paid for it, only because I currently have an absolutely mint used one on loan from my local L&M. They are selling it for $1299, and I just have to accept that I am buying the thing!
