New Marshall CODE digital amp series
Discussion in 'Marshall Amps' started by Moony, Jan 20, 2016.
  1. Plectrum
    Plectrum Active Member
    May 11, 2016
    258
    177
    UK
    Presence affects the high frequencies only. You need to reduce the resonance instead. I've found that using a 1x12 cab emulator helps to tame the bass on the amp models I use most (JTM45 and Plexi).
  2. Jethro Rocker
    10,246
    15,735
    The gate may have to be even lower. Speaker cab emulation choice does play a big part as well as mentioned. Open the back up on yours to see how it sounds, unless that buggers up your chance to return it. It sounds more open and less boomh. If you keep it, drill a big hole in the back. Honest. ​
  3. webcat
    webcat Member
    Mar 10, 2016
    59
    13
    I have lowered resonance and increased presence, and use a 1x12. I also disabled the cab sim to see how much of a difference that made.
    The boom is still there even with the cab sim disabled. I might open the back up if it's just a case of undoing some screws
  4. slagg
    slagg Well-Known Member
    Apr 7, 2012
    662
    344
    Cheezeland Wi
    From the clip you posted it sounds like you have the Bass way to high.What do you have the Bass control set at? I run mostly the Plexi model and have the bass at around 2 to 2 1/2. Like a real plexi its Bass heavy.If you crank a real Plexi you have to turn the Bass almost off.
  5. webcat
    webcat Member
    Mar 10, 2016
    59
    13
    It honestly doesn't make a huge difference. I turned the amp sim off and it still happens. In that clip the bass is at 4 on a silver jubilee model, because the overall tone is good at that level. If I roll the bass back further it's too tinny. The excess bass you can hear in the clip is what happens when I use the neck pickup
  6. Quoman7
    Quoman7 New Member
    May 6, 2016
    26
    11
    Try lowering your neck pick-up, it worked for me!
  7. webcat
    webcat Member
    Mar 10, 2016
    59
    13
    I've done that too
  8. mbell75
    mbell75 Active Member
    Jan 14, 2016
    355
    212
    You have several choices. Get an EQ pedal, use your bridge pickup or decide whether you want more bass or more tinny.
  9. slagg
    Apr 7, 2012
    662
    344
    Cheezeland Wi
    Bass on 4 on a Jube is pretty high IMO.Jube is a tinny amp.
    Could just be the "Crap" speaker that comes stock with this amp.If it has a light thin frame there's your problem. Speakers that come stock in "Budget" amps always suck. Cheapest of the cheap. $10 speaker, $10 sound.
  10. David Elliott
    David Elliott Member
    Jun 22, 2016
    65
    31
    That is the first thing I noticed when I replaced the stock speaker with the WGS...the stock speaker felt like it was mounted to flimsy metal and was just super cheap. The WGS is WAY beefier, and in my opinion is a worthy upgrade. Now, that said, I did got with an 8 ohm (rather than 4) GC does not sell them in 4 ohm and I got a $10 off for using my gear card. It wasn't expensive, and I love tinkering. Getting inside the CODE and reading the stuff from the guy that did the DIY rebuild, I like the idea of unmounting the electronics and building it as a head, then either sealing the rest up, building a custom cab, or buying one already built. The electronics/controls would make a super cool little head.
  11. jdjung
    jdjung New Member
    May 13, 2017
    I also like tinkering. I put in an output and input jack so I can used my Marshall Code 50 as a head and the speaker as a 12 inch cab. Took me about 10 mins. The Marshall uses standard unsolderd spade connectors. This means there is no soldering required to keep it in its stock format. FYI if you have studio monitors or home theater system do yourself a favor and use the headphone jack out or better yet digital usb out. It's really on a whole new level then the stock 12 inch. I'm trying to convince a friend to bring his Kemper in to compare the two. Soft tube did a great job and the sound through my receiver was jaw dropping.
    Dogs of Doom, mbell75 and mazzefr like this.
  12. Springfield Scooter
    Springfield Scooter Well-Known Member
    Apr 13, 2017
    1,217
    1,491
  13. webcat
    webcat Member
    Mar 10, 2016
    59
    13
    How much is the speaker you got? Does it affect the modelling aspects at all?
  14. David Elliott
    Jun 22, 2016
    65
    31
    GC $69 plus about $8 shipping, but I got $10 off as a promo for using my GC gear card. It is an 8 ohm, rather than a 4 ohm which comes stock in the CODE. But, you would gain the ability to attach another 8 ohm cab if you wanted.
    It changes the sound a bit, of course, so you have to play around with the settings to your liking. But the biggest difference is less boomy and flubby, tigher, and less directional.
  15. David Elliott
    Jun 22, 2016
    65
    31
    Really? Because I have a set of Event 20/20 Biamp studio monitors which sound amazing, and I have a set of Klipsch tower speakers with dual 10" woofers in each that are astounding.
  16. AllanAnd
    AllanAnd Member
    Mar 10, 2016
    36
    18
    Denmark
    I was wondering... Are the new Fender Mustang GT's "CODE killers"?
    Anybody tried them?
  17. Plectrum
    May 11, 2016
    258
    177
    UK
    Their Fender models are good just like on the previous Mustangs. Other stuff not so good. They're nowhere as easy to program as CODE is without using an app and unlike CODE, you can't manually toggle pre-fx, modulation, delay et al. So no more a CODE killer than their valve amps are Marshall valve amp killers. They're a different product aimed at different players.
  18. Martin Maniac
    Martin Maniac Member
    Mar 7, 2015
    40
    20
    Yes I have a Fender Mustang GT 40. AND I also just bought a Marshall Code 25. Why Both ?? The user presets that are developed by the communities are great. So I want the best of both worlds. Marshall and Fender. Yes I'll get some duplicate sounding presets, but I'll also get many more by doing it this way. The Fender presets I've already downloaded sound very good, they are real gems, I'm expecting I'll find the same with the Marshall presets as well.
    They are two different animals with much different sounds. I just ordered the Code yesterday and will get it Saturday. So I'm looking forward to working with both amps.
    I bought an iPod to work with the Fender Tone app and an Android 8" tablet to work with the Marshall Gateway app. The Android doesn't work with the GT40, an the iPod screen is small for the Gateway app. So yes it's a bit of a pain but should be worth it. I love the idea that both amps can record direct into my DAW with a USB hookup. I really think you need both.
    AllanAnd likes this.
  19. mbell75
    Jan 14, 2016
    355
    212
    Why spend hundreds of dollars on multiple amps for that? Spend $100 and get Amplitube 4. Its far superior to either the Code or the Mustang.
  20. Martin Maniac
    Mar 7, 2015
    40
    20
    I never heard of Amplitude 4 until you mentioned it. Too late !!
    I just checked it out, it reminds me of Guitar Rig 5 which I already have and don't use because software just doesn't do it for me. I want hardware.
