mbell75 said: ↑
172 pages and no one has tried overdrive pedals with the Code?!
While the Code is lacking a speaker out, I can't imagine why one would have to run it into another cabinet. However, if you wish to do this and still use the internal, it is 4 ohms and as low an impedance as Code will tolerate so NO external. Change out the internal to an 8 ohm, add a wire to a jack on the back and you can run another 8 ohm cabinet, if you really want to.I just picked up two Codes. A 25 and a 50
Initial impression is good. The more I play with them, the more concerns I have.
One complaint I have is the lack of a speaker cabinet jack.
Secondly... the audio playback when blue toothing or connected via the audio input is not good. Muffled. Blackstar did a much better job on the mp3 input circuit than Marshall has.
The setting changes when hooked into the marshall app via blue tooth are sloopopw
The built in effects are nice. The amp and pre amp models are good. Overall a good value for the money....but improvements are needed
Hey guys, please look at the backplate of your code 50. On mine theres said "code 50, 75 W". Well the speaker only got 50W. Got the Amp more watt than the speaker? Or is the "quality controll by Marshall England" so bad, that they can´t separate the three different models of the code series? Strange...
Thx for your answer, in opposite to other here you weren't helpful.You just noob'd all over yourself.
April fools or what?
https://reverb.com/item/4443546-mar...ries-100w-digital-head-w-2-way-footswitch-new
https://reverb.com/item/4443550-mar...-combo-2-x-12-speakers-w-2-way-footswitch-new
Anybody done business with Tundra Music in Canada?
Where is it made?
China? Vietnam?
A simple "what does this mean" question rather than wrongly slamming Marshall England for their quality control would have been better. Not to mention these amps are made in Vietnam, not England...
The Reverb listing for the 100 waters from Tundra Music in Canada is a scam.
Their listing shows them in stock.
I purchased one and they DO NOT have them available as their add states.
I received a refund, but very deceptive at best.
Buyer beware!
Just picked up a used 25 dirt cheap and I must say as far as "lower priced"modeling amps go this is by far the best of the bunch.It to me is the perfect "Bedroom/practice amp.Some of you guy's are picky,but I'm not.Get a good tone,GO!!As Frank Zappa said"shut up and play yer geetar"
I wonder what the problem is with the 100 watt'ers and if it's related to the poor performance reported by some owners of the 25 and 50 watt combos.......
