New Marshall CODE digital amp series
Discussion in 'Marshall Amps' started by Moony, Jan 20, 2016.
  1. Jalex
    Jalex New Member
    Jul 9, 2013
    24
    22
    I got my 25 a week ago.
    I had a crappy USB cable from a hard drive and I tried recording with it.
    I got intermittent artifacts in the sound, like a digital robot distorted voice or something.
    I then brought a new cable (some cheap sh**t still) but noow the artifacts are gone.
    They only come up if you remove, plugin the USB while you are playing or if you save a preset while connected to USB...
    I have no clue if this is a software error or a fucked up cheap cables issue.
    But otherwise USB direct recording and sound is great. Different than what you get from the speaker. And low latency (64 asio spls)
    I have a Yamaha 50M monitor set-up with subwoofer and the amp sounds amazing through USB via the Yamahas.
    CliffyG likes this.
  2. Iagtrplyr16
    Iagtrplyr16 New Member
    Jun 5, 2016
    18
    20
    Had an enjoyable session with my 50 last night. The models I've tweaked sound really good, but there are still a whole bunch left to do. I know this has been said, but what happened to the DSL of models? Yuck! No matter, for me the Jubilee, 800, and JVM more than make up for it. I'm gonna begin looking for something Voxy. Any suggestions?
    Jethro Rocker likes this.
  3. Benzel
    Benzel New Member
    May 11, 2016
    24
    13
    Thanks! I actually got it going very nicely now thanks to your tip!
    CliffyG likes this.
  4. C-4
    C-4 Member
    May 12, 2011
    39
    52
    I have found with my JMD-1 H, as with any other modeler, that there are going to be some models that one doesn't prefer for whatever reason.
    I just pre-ordered a Code 50 and pedal to go with it. Just from the videos on it, I already know that I will simply tweak a few of the sounds and go with those for the time being. I did that with my JMD and it's all I need. The factory presets can either be used as is, or be tamed and used really well.
    That is what I have done with every modeler I have ever had.
    I am really looking forward to the Code. Not only is it going to be fun using it, but it will eliminate extra gear that I currently have to haul around.
    Iagtrplyr16 likes this.
  5. C-4
    C-4 Member
    May 12, 2011
    39
    52
  6. Ghostman
    Ghostman Well-Known Member
    Jan 29, 2012
    10,321
    10,027
    Hopehouse, Selkirk, UK
    I owned the VT-30 and played the VT-50 quite a bit. No, they should not be considered. lol
  7. C-4
    C-4 Member
    May 12, 2011
    39
    52
    These are not the older Vox amps. I had those. These are brand new models.
  8. Frank S
    Frank S Member
    Apr 10, 2016
    76
    68
    I like the new Vox AV series
  9. Iagtrplyr16
    Jun 5, 2016
    18
    20
    Haven't tried either the AV or VT-X series, but owned at least one amp from each of the previous generations. I honestly thought the tone worsened with each new amp. The last one was the 80-watt combo that I sent back to Sweetwater because of the snare drum-like digital artifact after each chord. I've been Vox-less since.
    C-4 likes this.
  10. C-4
    C-4 Member
    May 12, 2011
    39
    52
    I found the same exact things you did with each new Vox update of the Valvetronix line, including the VT 80+!
    I was glad I kept my AD30VT. I used that amp for a long time and it sounded the best of any of them. It was totally stock too, it's entire life.
  11. Frank S
    Frank S Member
    Apr 10, 2016
    76
    68
    I had a VT20+ once and I thought the Vox models there fine but I did not like the sound of most other models. I tried the VT40+ and VT80+ models as well to confirm that it had nothing to do with the speaker size.
    The VT+ turned me off from all the Vox modelling amps.
    But the Vox AV series is different as it is analoge modeling (with tube in the circuits). When I tried the Code 25 in the store and did not like it that much I tried the Vox AV15 as well and liked that much that I own an AV30 now.
  12. khan
    khan Active Member
    Oct 2, 2010
    278
    32
    United States
    Man! Thanks for everyone's feedback. They're still not in the local GC here. I'm using a Crate Vintage Club 50 2x12 for practice and my JCM800 for live. I can never get the VC to sound how I want and I've got my 800 so dialed in with lower distortion preamp tubes that It'll be impossible to match. After reading the input in this thread, I'm pretty sure I'm ready to sell the VC and get the CODE for a practice amp. I do use a load of pedals in front of my 800 and VC so, I'm hoping I can either create patches mimicking those or they sound good enough in front of the amp for practice. Plus, even a new CODE 50 is less money than I should get for my VC. So, a few more bucks for the gear fund. Thanks again for everyone's input and knowledge.
    Iagtrplyr16 and Jethro Rocker like this.
  13. chrisjtm1
    chrisjtm1 Member
    Dec 1, 2012
    63
    28
    Bradford, UK
    Just picked up my Code50 one of the first in the UK according to the shop.
    Little disappointed if I'm honest, really wanted to love it as much as my JMD but little too easy to dial in some harsh sounding tones. Hoping the speaker will break in and it will grow on me more.
    Frank S and shooto like this.
  14. mazzefr
    mazzefr Well-Known Member
    Feb 26, 2016
    538
    599
    Pennsyltuky
    You really need to fiddle with it for a few days to make a proper assessment. I've had mine for over a month, play at least an hour a day and I keep getting better with it.
  15. Benzel
    Benzel New Member
    May 11, 2016
    24
    13
    I can confirm mazzefr statement. I too was disappointed at first, but as he said, you'll grow into using it. As I was instructed here before, pick pre-amp, power-amp and cab, but threshold,presence and resonance at low/0 and start building from there, it helped ALOT and I now have a couple of presets of my own that sounds absolutely splendid. Keep at it.
  16. Benzel
    Benzel New Member
    May 11, 2016
    24
    13
    Just a quick question, I've read in a lot of places that connecting a bass to a guitar amp can DAMAGE the amp? Is this true? And would it apply to the CODE too? I know it wouldn't sound good in any way, just curious and I want to try it out if it were to be harmless.
  17. Jethro Rocker
    10,246
    15,733
    You CAN. just keep volume low enough so the bass frequencies don't frap out that speaker and damage the coil.
    Frank S likes this.
  18. Benzel
    Benzel New Member
    May 11, 2016
    24
    13
    Hm okey, still sounds too risky. I'll just keep pitch shifting my guitar and pluck it like a bass in my recordings I think.
  19. C-4
    C-4 Member
    May 12, 2011
    39
    52
    One thing playing a bass through the Code might do is loosen up the speaker faster, but as mentioned, keep the volume down.
  20. Iagtrplyr16
    Jun 5, 2016
    18
    20
    Bass guitar is an octave below that of our electrics, so cranking up the volume and slamming the E will send that driver across the room! Okay, nave not across the room, but you can definitely damage it. You could run it at low power though without too much risk, and like C-4 mentioned, it may loosen the speaker up quicker. Just don't pop your strings while playing your funky stuff!
    C-4 and Jethro Rocker like this.
