New Dsl20hr, And A Problem...
Discussion in 'Marshall Amps' started by JuSu, Feb 19, 2018.
Tags:
  1. tce63
    Aug 6, 2018
    2,165
    6,038
    Sweden
    :welcome: to the forum
  2. Mitchell Pearrow
    15,267
    30,288
    :welcome: To the best amp forum there is ! Cheers Mitch
    tce63 likes this.
  3. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,265
    1,043
    Saginaw MI
    Mine has that same noise.
    It's not tubes. Been there done that.
    A noise gate in the loop does not stop it....its in the power amp stage after the pre-amp.
    I've had mine past the 'return' to where I bought it time frame, but it is under warranty.
    I should just break down and send it in.
  4. scozz
    Jul 20, 2008
    5,306
    12,316
    I can relate to that! I’ve got some hearing loss and tinnitus in both ears.
  5. solarburnDSL50
    Aug 8, 2008
    18,072
    14,894
    Wetville
    For sure. Make them fix it. You deserve a fully working amp. I have no doubt they will.
  6. scozz
    Jul 20, 2008
    5,306
    12,316
    Sounds like a microphone in the wind.
    Why are there so many, (or it seems like a lot), of these Dsl20 amps with problems?
  7. Mitchell Pearrow
    15,267
    30,288
    :shrug:
    tce63 and scozz like this.
  8. RobV
    RobV Member
    Sep 13, 2008
    90
    75
    I must have got a good one, I don't have that wind, just a little tube noise I have heard in numerous amps when turning them up, I am actually putting in some EHX's for power & JJ's in the Pre I have tomorrow. No issues with emulated out and headphones work perfectly. $400 dlvd for a new 1 was a good deal :)
  9. Sixstring63
    Sixstring63 New Member
    May 5, 2011
    10
    19
    It’s not tubes guys. I have one on the bench right now with that same popping crackling noise. It is in the ultra gain stage and has something to do with the crazy volume pot routing via shielded cables. I have changed out anything that would induce that noise on a normal amp with no luck yet. I have the schematic since I do some repairs for a Marshall dealer but they leave out the digital daughter board for the loop and emulated headphone jack. I think that’s t where most of the issues are. I have the dealer trying to get more info to get this thing off my bench and working right. They went off the cliff with changing the topology of this POS compared to the DSL 15’40’100 layouts. Just stupid layout that obviously didn’t work well. The schematic I got from them is DSL15M-60-02-v6, the amp is -60-00-v7 so that shows how many revisions they have done, and it still doesn’t show the factory fix that somebody posted before and after. I’ve modded the hell out of my DSL40 with ease, this bastardized thing is like nothing I’ve encountered. Plain and simple piss poor design on their part. Once again trying to improve the mousetrap. If it ain’t broke, don’t fix it.
    Armando, Mitchell Pearrow and tce63 like this.
  10. mickeydg5
    mickeydg5 Well-Known Member
    26,779
    13,961
    united States of America
    I do not want to hear about their 3rd world cheap crap!
    Sixstring63 likes this.
  11. tce63
    Aug 6, 2018
    2,165
    6,038
    Sweden
    I had a DSL20HR without any issues, EU version.
    And :welcome: to the forum.
  12. Sixstring63
    May 5, 2011
    10
    19
    You are one of the lucky ones. From what I’ve been reading people had more issues than not had issues with this model. Once I get it figured out I will share my findings. Traced the noise from second gain stage for ultra channel to loop send. Clean channel is dead quiet. Return loop signal is quiet too. Cheesy dual layered pcb makes impossible to trace it properly without pulling the board to which you can’t power it up out of the chassis. Pretty much a cheap throw away amp if it fails. That’s why I play old Marshall’s and a Friedman SB50. Reliable and easy to maintain with no crazy mp3 input nonsense.
    tce63 likes this.
  13. Sixstring63
    May 5, 2011
    10
    19
    You hit the nail on the head there Bro! My DSL 40 sounded like ass when I first got it. Modded it to my liking. Just bought it for small gigs we do one in while where I don’t have room for my big rig. This 20 is a nightmare layout. Strangest design I’ve seen.
    tce63 likes this.
  14. mickeydg5
    26,779
    13,961
    I should not have bashed it that badly but has anyone noticed more complaints about the new DSL series?
    scozz, Sixstring63 and tce63 like this.
  15. Sixstring63
    May 5, 2011
    10
    19
    Update! Finally got it figured out. Cap C4 (10nf) coupling cap from V1b to V2a was the culprit. It was throwing me off because the noise was showing up a bit at the grid of V1b too. The DC voltage at V2a was very high at about 11v and that kept telling me something was goofy, the voltage was negative to the cathode so I thought it was what they were after with a 8.2k cathode resistor with no bypass cap. I also replaced C9(1.5nf) in parallel with a 470k resistor that makes up a voltage divider with another 470k going to the grid of V2a. Both of these caps tested fine in circuit and out along with my old Heathkit cap tester at 400v. Little sob sure didn’t work in the circuit. Now I had about a grid DC of 0 and a cathode voltage of about 2.3vdc at V2a. Right in the same range of the other stages. Good lesson learned to trust my first instinct of the issue. I did upgrade quite a few parts that were revised to the newer schematic I got from Marshall. Thing really screams now. Funny thing is they would not give up the channel wiring factory fix that a member posted before and after shots on another thread. I asked the dealer I do work for to get the service bulletin and procedure, but all they sent was the two 1 meg resistor change in the resonance circuit. I found that in another post and tried that first thing. Anybody that has crackling, rustling and popping on the ultra gain channel of one of these change the parts I have listed. Should do it, especially if you have quite a positive dcv on V2a grid. More of these amps than not have these noise issues. Must have got a bad run of 10nf caps on this production time frame. All good other than a lot of time wasted. My fault, should have seen it sooner. Sometimes the stuff that is in front of your nose is the hardest to see.
    JBA, Strugs, nickfox and 7 others like this.
  16. Krisztian Nagy
    Krisztian Nagy New Member
    Dec 5, 2019
    Wow good job, congrats!
    Could you share this old schematic of DSL15M-60-02-v6?
    Armando, tce63 and Mitchell Pearrow like this.
  17. Mitchell Pearrow
    15,267
    30,288
    :welcome: To the forum
    nickfox, solarburnDSL50 and tce63 like this.
  18. scozz
    Jul 20, 2008
    5,306
    12,316
    Yeah, I've been talking about that for months! And the majority of the models too, the 100, 40, and the 20, I haven't heard too many problems with the 5, and I haven't heard about any problems with the 1.
    Last year just about this time, I was all ready to pull the trigger on a Dsl20h. Then I thought I'd wait till after the New Year and NAMM,....to see what, if anything, Marshall would be releasing. Well I can't tell you how happy I am that I did that, I bought a SC20h!
  19. mickeydg5
    26,779
    13,961
    I
    I guess its that great quality control they are on top of according to their business ethics.
    So how good is Euro-Union when you can send your manufacturing to the back hills of Vietnam getting things made for tuppence on a pound. Or is that part of the reason for Brexit?
    SC20h MADE IN ENGLAND
    Does anyone have to say more?
    SiCoul, tce63 and scozz like this.
  20. Armando
    Armando New Member
    Jan 21, 2019
    15
    12
    please can you share more of this work, some pictures will be appreciated
    Thanks.
