New amp day tomorrow, let's get serious.
Discussion in 'Marshall Amps' started by Sir Don, Jun 3, 2021.
  1. fitz288
    Apr 7, 2020
    3,042
    7,198
    rahndahbaht dah 'Burgh
    With the 8ohm extension, the impedance gets set to 4ohm.
    Seller might not have had the 6912, but could have been using any 8ohm cab.
  2. FracStrat
    FracStrat Well-Known Member Gold Supporting Member
    Jan 22, 2020
    963
    2,968
    Water Side of WA State
    The Stock Speaker should be 8Ohm ..
    The standard internal OT Tap On the Combo is factory wired for 4ohm or 8ohm .. The Head is factory wired for 16ohm or 8ohm .. Either can be internally re-wired ..
    The late ‘94 & ‘95 years were 5881 with no Lead Mod (LM)
  3. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,605
    1,452
    Adelaide, South Australia
    I asked him if he used an extension cab, his answer was in the negative.
    Hamer95USA and tce63 like this.
  4. Sir Don
    Aug 9, 2009
    1,605
    1,452
    Serial number shows it's a 94.
  5. Sir Don
    Aug 9, 2009
    1,605
    1,452
    I think I'll get my tech to take a look at it. All the preamp tube sockets are wobbly and a few noisy pots.
    Hamer95USA, tce63 and fitz288 like this.
  6. FracStrat
    Jan 22, 2020
    963
    2,968
    4ohm switch position indicates a standalone mismatch of course ..
    We’re you able to try it ?
  7. Sir Don
    Aug 9, 2009
    1,605
    1,452
    Yeah, I did try it, it all sounds ok but I think I'll get it checked out anyway. It was a cost neutral exercise and I was willing to pay $1050US for it so if it costs me to retube it I'm ok with that.
  8. Jethro Rocker
    9,985
    14,839
    Ooops. As long as it still works I guess.
    Check bias too. It uses different preamp tubes for each channel. Try to keep as many of those tubes as possible if original. There are lots of switches etc but not bad once you get it set up.
  9. Sir Don
    Aug 9, 2009
    1,605
    1,452
    An update on this one. My tech has had it for a few weeks now and says the internals have been messed with. It requires new caps and other parts which he has on order.
    I've told him to go ahead and do a full re-valve with, preferably, Tung-Sol 5881's and his choice of preamp valves.
    By the way, does anyone know where I can get the matching 6912 cabinet from? Bear in mind that I'm in Australia.
    fitz288 likes this.
  10. fitz288
    Apr 7, 2020
    3,042
    7,198
    That's probably not going to happen, I've never seen a 6912 by itself.
    The set I got was one of the few sets I've ever seen come up on Reverb.
    But the 6912 is basically a 1912 with the 200w speaker and the aniversary badge.
    Might be easier to just get a 1912 and upgrade the speaker.
  11. scozz
    Jul 20, 2008
    5,164
    12,010
    Sounds like it’s working out for you, congrats man!
    :cheers:
    Nice amp too,… :cool:
  12. Dogs of Doom
    25,775
    33,138
    Mitchell Pearrow and Sir Don like this.
  13. Sir Don
    Aug 9, 2009
    1,605
    1,452
    Thanks DOD, I just sent a message to enquire about postage costs, appreciate your help.
  14. Dogs of Doom
    25,775
    33,138
    the guy says he has a cab too, not sure what it is. If you get to talking w/ him, you might ask about it...
  15. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    2,033
    2,632
    Södertälje, Sweden
    It's my understanding the 30-ani amps does anything an 800 can and much more, so I think you'll do fine with it.
    I'm a bit surprised they are hard to come by stateside.. there's always atleast one coming up on the different swedish sale sites.. there's two blue ones at the moment... but then, Marshall was always the affordable amps over here compared to most others...
    J
