New 2X12 Cabinet Build
Discussion in 'Cabinets & Speakers' started by David Copeland, Sep 24, 2021.
  1. David Copeland
    David Copeland Member
    May 2, 2020
    33
    50
    I recently got a couple of Cerwin Vega ER124 speakers off eBay so of course I had to build a cabinet for them. This one was going to be 3/4" pine board with 1/2" ply front and back baffles. I was also going to figure a tuned port on the rear baffle. Well here are the pictures:
    IMG_20210909_203106r1.1.jpg IMG_20210909_204758r1.1.jpg IMG_20210913_202249r1.1.jpg IMG_20210916_101113r1.1.jpg IMG_20210923_115104r1.1.jpg IMG_20210924_095345r1.1.jpg IMG_20210924_095504r1.1.jpg
    Geeze, BlueX, Peter McAteer and 9 others like this.
  2. PelliX
    PelliX Well-Known Member
    Jun 16, 2020
    1,023
    1,720
    I like the Strat jack socket on the back - cool. Maybe add your own 'brandname' somewhere on the front baffle? :)
  3. pedecamp
    17,719
    17,586
    Interesting design with the opening at the bottom of the back. Did you test what it sounded like with the opening and without?
  4. David Copeland
    May 2, 2020
    33
    50
    No, actually, I measured the T/S parameters on the two speakers and did a tuned port design that resonates the box/speaker combination at approximately 71Hz for one speaker, 67 Hz for the other (difference in the T/S parameters), which is just a bit below standard tuning for the guitar low E string. The slot you see at the bottom is the size port called for to make this happen. Playing a bass on the low E string and walking down from the 12th fret you can hear where the cabinet/speaker unloads and stops producing the fundamental tone. Using a sealed box will only raise the resonant frequency which will cut off the speakers low end at a rate of about 12 db per octave. But I didn't do a sealed box design to see exactly where that would happen. Just it would be higher than the ported design for the same box size.
    pedecamp likes this.
  5. David Copeland
    May 2, 2020
    33
    50
    The Strat jack plate takes up way too much space on a guitar IMO; but for a speaker cab where there's lots of room I like it since it doesn't stress the cable or the phone plug pointing down like that. And yes, I'll probably add one of my logos to the cab just as I have on the amp.
    BlueX and PelliX like this.
  6. Johan
    Johan Member
    Dec 4, 2020
    15
    48
    Beautiful woodwork, but IMO the cab would look soooo much better with a nice grill cloth instead of the bare black baffle and metal speaker covers.
    Ufoscorpion and David Copeland like this.
  7. David Copeland
    May 2, 2020
    33
    50
    It probably would, and I may well do that in the future. I just haven't gotten around to it at this point. But your comment does beg the question; what grill cloth style would work best with this? Salt and pepper, some sort of light tan, basket weave?
  8. David Copeland
    May 2, 2020
    33
    50
    BTW, I really like the way these sound.
  9. Dogs of Doom
    25,841
    33,369
    or, you could get a full face metal grill custom made...
    PelliX and David Copeland like this.
  10. fitz288
    Apr 7, 2020
    3,134
    7,460
    rahndahbaht dah 'Burgh
    I used a similar speaker grill on my MG15 micro cabs build.
    The baffle plates are made from OSB and covered with a thin sheet of black ABS plastic that has a textured surface.
    I used an adhesive between the two, but it's also held in place by the face frame and the speaker grills.
    Not a grill cloth, and a nice covering to hide the OSB.
  11. Johan
    Johan Member
    Dec 4, 2020
    15
    48
    I’m a sucker for Marshall large check, but on this cab I think Vox diamonds would look fantastic.
  12. Dogs of Doom
    25,841
    33,369
    I was on my way out, when I posted this. I ordered my grill from here:
    https://www.reliablehardware.com/customspeakergrill.aspx
    I ordered black expanded metal. I had the edges bent (all 4 sides) inward towards the cab. Then you order a dense, black rubber spacer tube w/ screws & washers to install the grill...
    On mine, I did a 1" bend, the depth of the cab face is deeper than that, but, there are braces, that are just about 1" deep.
    Edgar Frog, Geeze, BlueX and 3 others like this.
  13. PelliX
    Jun 16, 2020
    1,023
    1,720
    I really like @Dogs of Doom 's idea with the metal front, but the VOX diamonds... would be the winner for me. :applause:
    David Copeland likes this.
  14. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,876
    3,801
    Nice looking cab! I really like the clear finish on the pine - lacquer or other?
    Regards,
    Russ
  15. David Copeland
    May 2, 2020
    33
    50
    Thank you! Actually the finish is several coats of wipe on poly. While it's somewhat time consuming it doesn't require a whole lot of effort.
    Geeze likes this.
