So I bought a JCM800 4212 a few months back and it doesn't sound so good. It was from seller on Reverb and we met in a car park about half way between our respective homes so I didn't get a chance to listen to it before buying but the seller had 100% good feedback. Also I figured it's 30-something years old so it might need some TLC to get it sounding good again. I used to own a 100w version of the same amp that I'd bought new in the mid-'80s that sounded better and had more gain on the dirty channel too.
I took the amp for servicing and the power valves were replaced, also I was advised to use the clean channel and I think the technician put a preamp valve in that causes the clean channel to break up more readily, he also told me to use pedals for overdrive and forget about the dirty channel but that's not really why I bought the amp or the way I'd intended to use it. The technician checked it for faults but it wasn't tested in a 'subjective' way, if that makes sense, i.e. for tone.
The clean channel sounds quite woolly, lacking in treble which is what makes me think there might be a valve that breaks up easily that's been put in there for the clean channel and there's still not as much gain as I remember getting on the dirty channel of my 100W version, yes it certainly overdrives but not as nicely as I'd like it too and I'm having these tonal problems
I've tried a couple of OD pedals on both channels (Bogner 'LaGrange' and a Tube Screamer Pro) and yes I get more gain but they don't sound very nice, there's a lot of background hiss when I use either the OD pedals or my Orange Kongpressor pedal with the 'squash' turned up, also my Boss DD200 sounds 'not right' through this amp, I have to turn the effect level WAY down before it begins to sound some approaching what I was used to getting but I can't help thinking the amp is affecting it.
I'm not connecting any pedals up to the effects loop.
I returned to playing electric guitar a couple of years ago but in the past when I'd bought new or used valve amps I'd automatically replace at least their preamp section valves with Mesa Boogie items as they always sounded better than the stock Marshall / Peavey / whatever items.
Should I replace the preamp valves with Mesa Boogie items this time around or are there maybe other brands that would sound better in this amp? Maybe I'm not approaching this in the right way either. Ideally I'd like the clean channel to sound fairly bright as well as clean and the dirty channel to have a decent amount of gain; I never needed to use an additional overdrive pedal with my last dual-channel JCM800
Are there any of the 5 preamp valves in this amp where something other than a 12AX7/ECC83 might be a better choice?
The last time I owned electric guitar equipment there wasn't the benefit of the internet for sourcing valves or anything else but now I find I'm spoilt for choice to the point it's become mind-boggling. The only reservation I have is that I won't use any Chinese-made items as I boycott any goods of Chinese origin.
Could it be that there's other things not right with the amp? I've not checked what brand(s) the preamp valves are yet and I took it to a reputable technician for servicing.
Any opinions or advice would be greatly appreciated, I'd very much like to get this amp sounding good again
