Need help with tv (Samsung)
Discussion in 'The Backstage' started by Ramo, Oct 26, 2021.
  1. Ramo
    Ramo Well-Known Member
    Feb 13, 2019
    1,364
    3,341
    Hey gang
    I was wondering if any if you can help me with my stupid tv?
    problem I have is… It wont pick up live tv feed from antenna. I tried different antennas but nothing…. I used same antennas on different Tv and they work fine on other tv.
    On this tv tuning menu is greyed out, so I cant search for Tv channels….
    I should note it was working fine till I decided to retune it to see if there was new channels.
    I restarted it to factory settings and nothing… Netflix, Amazon Prime and so on they still work fine.
    model is UE55MU6670
    Thanks in advance for any help.
    Vinsanitizer likes this.
  2. Dogs of Doom
    26,367
    35,002
  3. Ramo
    Feb 13, 2019
    1,364
    3,341
  4. Dogs of Doom
    26,367
    35,002
    it was right there, unless some regional shenanigans...
    I looked up a couple of sites, they basically said to make sure that you have the TV set to "air" as input. If you have HDMI, or DTV, or Cable, it won't do it...
  5. Ramo
    Feb 13, 2019
    1,364
    3,341
    I checked it again, I disconnected all HDMI cables just left areal in. Broadcast came back on but autotune is still greyed out.
    I make sure tv source is selected while Im trying to autotune channels but still no luck.
    Unless Im not understanding something…..
  6. Vinsanitizer
    Vinsanitizer >>> Fridgerator <<< Double Platinum Supporting Member VIP Member
    Oct 19, 2012
    31,572
    29,965
    Here's a couple of things you can try:
  7. Steve Whiting
    Steve Whiting Active Member
    Nov 10, 2020
    47
    166
    In your source selection, you should have tv, hdmi 1, hdmi 2, etc. You have to get rid of the tv+ app where your tv app is. Then go into your settings and change over to air. Should let you scan for channels after that. Had to do the same thing about 3 weeks ago.
  8. Vinsanitizer
    Oct 19, 2012
    31,572
    29,965
    NOTE: Try the two steps in the vid I posted first because one method relies on the TV+ item. Failing that, move to this post.
  9. DreamerDeceiver
    DreamerDeceiver Well-Known Member
    Jul 9, 2021
    1,386
    2,926
    OZ
  10. Steve Whiting
    Nov 10, 2020
    47
    166
    I couldn't get anything until I disabled tv+. Worked perfectly after.
  11. South Park
    3,818
    3,550
    Thar is no analog TV it is all cable or direct TV
  12. Ramo
    Feb 13, 2019
    1,364
    3,341
    How do I get rid off tv+?
    @Vinsanitizer I already done what he is saying in the video.
  13. Ramo
    Feb 13, 2019
    1,364
    3,341
    Some analog some digital…
  14. Steve Whiting
    Nov 10, 2020
    47
    166
    Can't remember exactly. Might be just press the down arrow on the Samsung remote when you have it highlighted. Should give you the move/remove option. Really wish I remember exactly what I did. Was just flying by the seat of my pants when I did it.
    May have to open the app and go to settings. Should give you the option to disable it there, but still, I'm guessing. Just know it needs to be disabled.
  15. Ramo
    Feb 13, 2019
    1,364
    3,341
    I remove the app but it dose not give me options to disable.
    how to check again tomorrow, its 2 am here now… I try again tomorrow with this shit tv…
    thanks everyone
  16. Steve Whiting
    Nov 10, 2020
    47
    166
    Removing it should work. As I said, I can't really remember exactly how I did it. Just hoping you can get some free tv out of it!!!! I got 36 channels on a homemade antenna.
  17. ricksdisconnected
    Aug 11, 2019
    11,872
    20,450
    thats why you should buy porn dvd's and not stream it.
  18. stickyfinger
    Nov 11, 2010
    809
    405
    Exit out of what ever app you are in and go to live TV. Go to settings and broadcasting should selectable.
  19. pedecamp
    18,303
    18,856
    Anything samsung is crap, throw it out and get something else.
  20. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    2,812
    2,898
    Broadcast tv? Is that still a thing?
    DreamerDeceiver and Vinsanitizer like this.
