Need advice: SOAD metal tone with Marshall SC20H?
Discussion in 'Marshall Amps' started by Old Punker, Feb 28, 2021.
  1. Old Punker
    Old Punker Well-Known Member
    Jun 17, 2020
    722
    1,740
    Ontario, Canada
    Hi all. I know some of you guys play heavier stuff on your Studio Classic amps. I've liked System of a Down for a long time but I've never had an amp that I thought was capable enough in stock form. I know they used layered tracks and a lot of studio tricks producing their Toxicity album, but would it be possible to get Daron Malakian's core (distorted) guitar tone using my SC20H without doing any permanent mods to the amp, and at a neighbor-friendly volume? I mean convincingly close, not exact. I know he used LP's and SG's as well as JCM 800's. Here is an example of what I'm after:
    or this (different album)
    I would appreciate any tips, suggestions, a starting point? Here's what I currently have to work with:
    • Marshall SC20H + SC212 cab (all stock)
    • Fryette Power Station PS-2
    • Gibson Les Paul Studio (498T), Gibson SG '61 Standard (57 Classics)
    • Boss SD-1, GE-7, BD-2, DOD 250 ri, RAT 2
    I would like to get most of my gain (and tone) from my amp, as little as possible from my pedal(s). I am willing to get a new pedal or other gear, if required.
    I'm not saying that I can play like DM, but I want to at least get the tone right and then work on the rest. I'm mostly a punk player...but would like to add some metal skills!
    Please let me know if this tone is not achievable with the SC20H.
    Thanks! :cheers:
    Sapient and GregM like this.
  2. clutch71
    clutch71 Well-Known Member
    Sep 26, 2007
    1,706
    1,246
    Columbus, Ohio
    Les Paul>Boss SD-1 (level maxed, gain and tone @noon)>into SC20. Gain @3 o'clock. mids, bass, treb, presence to taste.
  3. Dogs of Doom
    23,500
    27,493
    he really doesn't have a very "driven" sound. The bass has more drive than the guitar, that's why when the bass & everything are ramped up, it really gets there. Listen to the guitar, when the bass drops out.
    That's the sound you're going for.
  4. Old Punker
    Jun 17, 2020
    722
    1,740
    Ontario, Canada
    Thanks! Do you cover any SOAD?
  5. Old Punker
    Jun 17, 2020
    722
    1,740
    Ontario, Canada
    Yeah, I vaguely remember trying this years ago with my LP Studio through a Mesa Express 5:50 burn channel. I think I turned the bass up too high and it all turned to mush. I also figured it wasn't quite the right amp for it.
  6. Dogs of Doom
    23,500
    27,493
    you could probably get that w/ a Mesa...
  7. Neptical
    Neptical Well-Known Member
    Jun 13, 2010
    371
    803
    NH
    You have all the gear to do it.
    First: Drop C or Drop D Tuning.
    Second: Another very important factor in any drop tuning that is often not discussed is a Noise Gate. Very important to tighten everything up which brings me to...
    Third: Boss SD-1 ( as mentioned above). Clean boosted to drive your input. Don't use a lot of gain on your Marshall, let the SD-1 pummel that input. This pedal works fantastic with an ISP Decimator noise gate that I currently run.
    Start your Marshall off with some good chunky bass and good amount of mids. Don't use too much Treble ( very, very small touch ..its where the fizz lives) Presence to taste for some added sparkle.
    With the Drop Tuning, everything will sound fat and tight in tandem with your gear!
    Mitchell Pearrow and Old Punker like this.
  8. Old Punker
    Jun 17, 2020
    722
    1,740
    Ontario, Canada
    @Neptical Thanks! I am not clear on the noise gate. Currently I have no noise-related issues with my SC20H (even when boosted), and doesn't the SD-1 already tighten everything up? I went to the Decimator site and got confused :scratch:. Does the noise gate go in the FX loop?
    SD-1 level max, drive ?
    scozz, Sapient and Mitchell Pearrow like this.
  9. clutch71
    Sep 26, 2007
    1,706
    1,246
    Columbus, Ohio
    Yes some not in a band though. You just need the SD-1 to add a touch of drive to the SC20.
  10. Sapient
    Sapient   Silver Supporting Member Platinum Supporting Member
    Mar 14, 2020
    2,325
    4,470
    Yes
    The gain in the second tune is not high at all actually, but it's got some chug. Seems more Mesa territory, but I think a raw JCM 800 will do it nicely too.
    Very rectifier sounding in the first one.
    Old Punker and Mitchell Pearrow like this.
  11. Neptical
    Jun 13, 2010
    371
    803
    NH
    @Old Punker You're welcome my friend. The SD-1 (volume max, tone max, gain zero) tightens your tone while the Noise Gate filters out any unwanted hums,buzzes,noise,etc between your riffs. It just further tightens everything together. Very handy for anyone playing with a good amount of gain, palm muting syncopated riffs, etc. I have an ISP Decimator before my amp after my SD-1. Works like a charm.
  12. Mitchell Pearrow
    13,280
    24,935
    My grandson used to get a very good tone for SOAD using at first a Dsl40c - paired up with his TH30 Orange amp
    The tuning is the key and the SD1, he does it now with just the Orange, and SD1, but I am just repeating what has already been said, play around with the drive knob on the SD1. Level max, tone at noon , drive at 9:00 give that a shot.
    Cheers
  13. Mitchell Pearrow
    13,280
    24,935
    I had just caught my error in my post and edited it ha ha
    scozz, Sapient and Old Punker like this.
  14. Old Punker
    Jun 17, 2020
    722
    1,740
    Ontario, Canada
    Thanks Mitch! Yeah, I thought you meant 'drive' anyway. :cheers:
  15. Mitchell Pearrow
    13,280
    24,935
    Yea I caught it when I went back to read it lol
  16. Old Punker
    Jun 17, 2020
    722
    1,740
    Ontario, Canada
    I read somewhere he used both Marshall's and Rectifiers.
  17. Old Punker
    Jun 17, 2020
    722
    1,740
    Ontario, Canada
    Thanks for the tips guys, much appreciated!
    Now all I have to do is replace the 8 month old strings on my Les Paul and give it a try.
    :D
    scozz and Mitchell Pearrow like this.
  18. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    2,309
    2,240
    Isn't this more into 6505 territory?
    Just get a Peavey Vypyr for $50-70, a Bugera 6262 for $200ish, or a Peavey 6505 112 combo for $300-350 imho
    Old Punker likes this.
  19. LPMarshall hack
    Nov 18, 2009
    11,164
    11,463
    San Diego, CA
    Didn’t he use a Mode 4? Or did he just endorse them...?
  20. Gaz Baker
    Gaz Baker Well-Known Member
    Feb 15, 2017
    498
    1,643
    A lot of great answers, but like most posts around tone, no one has mentioned anything about pickups.
    To get someone's specific tone, I would imagine this would be intergral.
    Pick up selection has become an obsession for me.
    scozz and Old Punker like this.
