Need A New Amp!! What Am I Describing Here? Whats For Me??
Discussion in 'Marshall Amps' started by riffpowers, Jan 10, 2019.
  1. Jason Fieldhouseespk
    Jason Fieldhouseespk Well-Known Member
    Apr 21, 2018
    487
    656
    I mean, how much gain do you really want??
    This is gain maxed and volume 3 o'clock... not even with the boost...
    And this lad has it turned down so quiet you can hear his strings clacking, could you imagine if it was turn up?
    This guy has it getting quite crunchy, by 6 mins in gain is up max, and yes on the high setting, with the volume down it's not so overdriven, granted.
    Then at 6 mins he switches it down from mid to low, now he can turn that volume up to 6(conservative), and it starts to overdrive....
    Then he chickens out and turns it back down before putting the boost on... but what if he didn't back it off? What if actually he maxed the volume and hit the boost? Mushy right?
    Flick it back to mid power... THAT is a righteous overdrive and distortion in spades, don't need no pedals with that, just some beefy pickups and chug away...
    Well, that's what the guy in the first video did, that's without the boost...
  2. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    9,952
    9,246
    North
    Wow , this is a great oportunity to not answer with standard response. I don't have a absolute answer but it sounds like you are in great place , 1 you know what you want and 2 your geographic location . " Chapers" Rob Chapman has a amp company or he is involved. Anyway , Victory amps RD1 ytube demo and Silverback is the new Swiss army knife leaning toward metal . Check those out.
    Also check out Carlsbro , they to be inovative. There are others I can't remember.
  3. Kinkless Tetrode
    Aug 17, 2017
    1,689
    2,486
    Looking at some of the options that have been given:
    Origin. This is good for essentially your old set up of Les Paul > boost pedal > single channel amp that you were using, but scaled down in size, weight, and volume. The loop is switchable which could help set up a solo boost. Simple and straight forward.
    Mini Jubilee. It will do what you want by using the above formula of guitar then pedal into the clean/crunch channel, and then switching to the lead channel for a solos. The Jubilee is a darker, thicker sounding amp than the 800s your used to, though. The mid focus is shifted down. And it's picky about speakers. What speaker/cabs do have?
    DSL40CR or 100HR. The DSLs have two channels and two modes in each channel. The classic channel in crunch mode is a good platform for a les Paul >boost pedal> single channel amp. The new DSL R models have an assignable extra master volume which you can switch in for a solo boost.
    Some other Marshalls:
    JVM JVMs can do a pretty good 800 type tone among many. JVMs are multi channel amps and each channel has three gain modes: green, orange, and red. You could set one up to have an 800 like guitar through a boost into a single channel amp sound, and another for your solo tones, and in the case of the four channel JVM a completely clean channel, all at any volume. Not as simple and straight forward but very versatile.
    Vintage Modern The VMs have been out of production for several years so you have to go used. But these amps are good for the guitar straight into a single channel amp approach, and they are much more manageable in terms of volume control than an 800. They don't have a solo boost facility, but they respond extremely well to adjustments of the guitar's volume knob. They are like a four holer but the channels are already jumped internally. You have to blend bassy and treble sounds using the Detail and Body gain knobs. They have two modes in a single channel type arrangement. Low Dynamic Range is good for putting a boost out in front. High Dynamic Range cuts in an extra preamp tube so no pedal is needed.
    JohnH and Mitchell Pearrow like this.
  4. ibmorjamn
    Nov 3, 2012
    9,952
    9,246
    North
    Not a lot of the new carlsbro on youtube , I never played one but in Europe you should be able to find one.
  5. Jethro Rocker
    10,126
    15,345
    Interesting and good to know considering how the Origin is marketed. With an attenuator, most amps would work I guess. OP plays metal from through the 80's so a fair amount of gain would be required or the ability to turn up the master as per some of the videos.
  6. Jason Fieldhouseespk
    Apr 21, 2018
    487
    656
    Indeed, just no one has turnbthe volume to max yet... ;-)
  7. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,372
    2,380
    Wa State
    I wish you had been over on TGP to save me …… got chewed up and spat upon !!
    houseofrock and Mitchell Pearrow like this.
  8. Mitchell Pearrow
    15,290
    30,392
    Then I would have gotten an instant ban , because I would have flooded the page with origin clips lol , I happen to like the amp, maybe more than some, but I also let my ears tell me what I precive as good tone, of course ymmv! Cheers Mitch
    Jon C likes this.
  9. Mitchell Pearrow
    15,290
    30,392
    I am using an SD1 the gain is 8, low power setting, volume at 4, it does sound better when you turn it up further, but this is where I have to set it so the phone won’t clip, it’s my only means of recording/sharing the information I have gained on the amp! Cheers Mitch
    mikebinthesky likes this.
  10. Jr Deluxe
    Jr Deluxe Well-Known Member
    Sep 12, 2017
    274
    274
    Studio 15. And any clean boost pedal. Or better yet. Mono price 15. Yeah that's right. More like a jcm800 than any dsl or origin. The preamp section IS from a 2204.
  11. pedecamp
    18,012
    18,160
    2525H
    ORI20HR
    DSL20HR
    Come to mind
    Jason Fieldhouseespk and tce63 like this.
  12. JohnH
    JohnH Well-Known Member
    May 31, 2008
    4,693
    2,777
    Wilton NSW
    What a great summary! That's the best post I've read on the internet this morning.
  13. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,837
    4,847
    good advice up there^^^!! i would offer the DSL side of things, I have 100h & cr40 made into head. Also have PTP jmp50 2204 & 6100. all these amps can do the 800 thing pretty well with many dif flavors, i did studio work last year with the 40cr and jmp..very good results..now for gigging..the DSL..all day long.. classic chan 1 green .very and i mean very good clean..chimey at times..then red..a nice thick od but will clean up with guitar vol knob. both chan can be boosted nicely..now Ultra..dang man was i surprised..hot rodded 800-900 type sounds and i use gain on 3 to 5..(10 oclock to noon) i did drop c and D and very crunchy heavy mutes in E and mostly hard rock with Gibsons strait in,,,gigging..i have 4 progressive stages of gain set up by footswitch and then the 2 chan switches..the 20 watt is cool for practice and 40 is full...DSl100 very similar but slightly more old school(mines modded)..this CD, going to use that and 6100 to record for something dif--this one has the most insane punch i ever felt, it weighs a ton and the amp is big sounding.. chan 2 800 sounds are crazy good and then chan 3 is 900 but non fizz.. am going to gig the dsl's cause of ease of use and 4 basic sounds i use live..
  14. shooto
    shooto Well-Known Member
    Oct 22, 2011
    2,047
    1,256
    Denver, CO
    Get a jet city Jca 22 and throw a RFT in v1, a Mullard in v2 and you’ve got your rig
  15. dro
    dro Well-Known Member
    Aug 1, 2015
    1,273
    2,228
    Blue Springs Mo
    A lot of people use the DSL, I never tried one myself. All I can say for sure is the Jubilee was a first cousin of the 800. I like mine better than any other small amp I've tried. But I am pretty picky with tone.
  16. Kinkless Tetrode
    Aug 17, 2017
    1,689
    2,486
    Thanks.
    tce63 likes this.
  17. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    1,418
    2,546
    DSL40CR. Loads of sounds, none of them bad. Far better than the price would suggest..
  18. thunderstruck507
    thunderstruck507 Well-Known Member
    Apr 20, 2017
    314
    356
    Perhaps there was something wrong with the one I messed with. I am pretty sure I dimed the gain and used the boost and it was just a crazy bright thin clean tone, maybe on the edge of some breakup. It certainly didn't sound like the videos you posted.
  19. mulletmule
    mulletmule Active Member
    Nov 19, 2013
    321
    180
    Rochester NY
    The JCM 900 MK III is a single Channel amp with 2 master volumes. It has a 800 like circuit that can have diode clipping added in. Or just go all out 800 style without diodes.
    The SLX is a great all tube choice
    BftGibson, Mitchell Pearrow and tce63 like this.
  20. mulletmule
    Nov 19, 2013
    321
    180
    Rochester NY
    I would suggest a JVM. Tons of options
