NAD Jet City JCA20H - Update New Grill!
Discussion in 'Other Amps' started by Filipe Soares, Aug 10, 2020.
  1. Filipe Soares
    Mar 8, 2019
    1,524
    2,654
    I'll probably order with Bryce this week
    1) octal mod (I have a pair of JJ EL34s here. so its almost the same price as replacing the chinese EL84 for something better)
    2) FX Loop - I would normally go with the metropoulos, but it will save me the shipping costs from a different vendor
    3) Brown Iris Phil X - it's the same brown iris mod with 2 extra flavors (switchable)
    jchrisf likes this.
  2. Filipe Soares
    Mar 8, 2019
    1,524
    2,654
    This was the best idea ever. I´ll 3D print something similar to this:
    any ideas on how to do a metal front grill to this amp???
  3. stickyfinger
    Nov 11, 2010
    655
    277
    You mean 394v? I cant imagine 494v and tube life. Had one of these when they first came out. Wast the tone I likes so I modded it and eventually sold it as it never sounded good. Cheap parts or what ever it was but the PCB learning experience was worth the 300$!
    J Saw likes this.
  4. Filipe Soares
    Mar 8, 2019
    1,524
    2,654
    nope, 494. I´ll check that again later, but it was too high. the good thing is these tubes won´t be in the amp for a long time. my aim is to install some EL34s that I have in my parts bin.
  5. J Saw
    J Saw Well-Known Member
    Apr 26, 2017
    868
    1,491
    VA
    Yeah. 494 seems way too high. Both of mine run around 360.
  6. Filipe Soares
    Mar 8, 2019
    1,524
    2,654
    I`ll test with a different multimeter when I´m back home. that was way too weird, but it sounds good!
  7. thetragichero
    Jun 6, 2010
    2,630
    735
    flo rida
    had the 50w combo that i modded. didn't give any funky names to the mods just figured out what i wanted from the schematic
    not dumping so much gain from the crunch channel makes that where the best tones are. just ends up being louder than the overdrive channel for similar master settings because it's not going through that cold clipper stage with the 39k cathode resistor (can easily be adjusted if you set the knobs with your ears rather than your eyes)
    all in all though i was impressed with the stock build quality. they use some beefy iron
    jchrisf likes this.
  8. Filipe Soares
    Mar 8, 2019
    1,524
    2,654
    Just got home, mod time!
  9. Iron1
    Iron1 Well-Known Member
    Aug 14, 2020
    124
    259
    South Texas
    Where did you get the grill - I'm looking at a 22 and it has the old, ugly tweed grill on it.
  10. Filipe Soares
    Mar 8, 2019
    1,524
    2,654
    There´s a guy here that cuts this kind of grills for speakers. I measure the head and asked him to cut it. In the end the cost was like 10usd with the delivery costs.
    Iron1 likes this.
  11. Filipe Soares
    Mar 8, 2019
    1,524
    2,654
    Just out of curiosity. while the mods from bryce are not here, can I change the Bias from some 12AX7 for more gain???
    I was thinking about changing R29 or R25 or R43 or R20 for something different so I can get more pre amp distortion.
    What are your thoughts @NewReligion ?
  12. jchrisf
    jchrisf Well-Known Member
    Feb 27, 2016
    936
    1,051
    You motivated me to get mine out again. I also put my speaker cab on the floor of my closet and it sounds much better. This 22H rocks! I want to get a 20H since it is not as complicated to mod. Here is mine.. it has a Mercury Magnet transformer and a choke. Not sure what other mods were done because I bought it from GC.:headbanger:
  13. South Park
    2,907
    2,407
    The cathodes resisters look good for gain already . You might drop the grid stopper value to get more signal R 27 and increase R 13 to 470 k to dump less signal . That preamp look a lot like a 2204 the same mods might work
