Most secure strap locks
Discussion in 'Guitars' started by Sg-ocaster, Feb 7, 2021.
  1. Dogs of Doom
    23,903
    28,357
    w/ Les Paul, the best were the old strap buttons that came on the guitar...
    Maggot Brain likes this.
  2. donwagar
    donwagar Active Member
    Nov 24, 2018
    63
    166
    I use Schallers on all my guitars.
    Metlking and DirtySteve like this.
  3. DirtySteve
    DirtySteve Well-Known Member VIP Member
    May 25, 2010
    14,917
    13,776
    High & dry in TN
    Those red rubber washers that come on Grolsch beer tops slipped over stock strap buttons work really well. Now I use Schaller strap locks and I don't get the thing about the screws loosening up, I've never had that happen.
  4. joe_cpwe
    joe_cpwe Well-Known Member
    May 29, 2020
    240
    518
    Always have used Dunlop, never had a problem, ever, so I've never tried the others.
  5. tce63
    Aug 6, 2018
    2,013
    5,545
    Sweden
    I use this on all my guitars.
    Cheap and works great for me.
    Dogs of Doom likes this.
  6. Matthews Guitars
    3,750
    5,656
    I've been using Schaller strap locks for over 30 years. If you pay attention to them and don't let hardware get loose, they'll never fail you.
    I drill out the button by one screw size and use oversized extra length screws to anchor them to the body. I have to grind the outside of the screw head to make them fit.
    And for the strap side, don't forget to use a little bit of locktite threadlocker on the securing nut.
    Never had a button get loose or fail. They just WORK.
  7. dragonvalve
    dragonvalve Well-Known Member
    Jan 16, 2010
    1,019
    979
    If the screw is too loose I stick a toothpick in the hole with some Elmer's wood glue and reinstall the screw.
    anitoli and Dogs of Doom like this.
  8. G the wildman
    G the wildman Well-Known Member
    Feb 7, 2016
    842
    1,133
    London UK
    Same for me most nights
    Vinsanitizer and tce63 like this.
  9. fat_lenny
    fat_lenny Well-Known Member
    Dec 12, 2015
    873
    912
    Newcastle, Australia
    Ive got both the new and old Schaller locks. Never had an issue with the old ones, but found with the new ones the grub nut works loose and Ive had to use a bit of lock-nut to keep them tight.
    The new ones are more pleasing on the eye, but I prefer the older version.
    tce63 likes this.
  10. mwaley
    mwaley New Member
    Jan 17, 2020
    10
    15
    $4.49 a set at Sweetwater.com. I have 4 sets in my Les Paul case. They are a bit to get used to. To get them off you physically have to pull up on the top part to clear the strap button, then slide it off. They work great.
    D'Addario PW-DLC-01 Dual- Lock Strap Lock
    Trumpet Rider and tce63 like this.
  11. Dean Swindell
    Dean Swindell Well-Known Member
    Mar 12, 2017
    287
    267
    These buttons make locks obsolete. Still think you need locks? Nobody's beaten the Schallers and they're the least fugly, problematic and ridiculous.
  12. 21fret
    21fret New Member
    Mar 29, 2018
    21
    18
    Most secure ?
    :D
    WellBurnTheSky and tce63 like this.
  13. guitronics
    guitronics New Member
    Dec 19, 2010
    16
    12
    Dunlop. They are great with heavy Les Paul's. And a Wide strap! I had to grind down the screw head a bit...a drop of oil on the balls, once a year, and a bit of Lock Tite on the Strap part...it is done, for good...and a tug on the strap when re-attaching. Done for the life of the strap.
