Modding blind but now l see...
Discussion in 'The Workbench' started by shredless, Sep 15, 2020.
  1. shredless
    shredless Well-Known Member
    Sep 15, 2010
    4,841
    3,052
    I spent a few hours today diagramming and figuring out circuitry instead of just swapping parts willy nilly
    wakjob, ricksdisconnected and neikeel like this.
  2. shredless
    Sep 15, 2010
    4,841
    3,052
    Its been on the kitchen table for three days because l cant bring myself to drill a hole for my era switch toggle. Im making sure its a keeper before l drill
  3. South Park
    2,906
    2,403
    Some times it is best to take a break from some projects . Those circuit boards are not easy to work on . So what is the mod
    shredless likes this.
  4. Matthews Guitars
    2,541
    3,653
    Rather than drill for a toggle switch, replace one of the potentiometers with one that has a switch built into it. Like the CTS switch pots sold by Stewart-Macdonald, which have a built-in DPDT switch suitable for almost any wiring mod.
    jmp45, shredless and neikeel like this.
  5. neikeel
    4,624
    3,023
    CTS and Alpha do push-pull pots (the Alphas are double pole too)
  6. anitoli
    8,227
    10,235
    2203X, yes?
  7. shredless
    Sep 15, 2010
    4,841
    3,052
    Yes lm thinkin a pot, but can l get a on off on? I wanna go both ways
  8. shredless
    Sep 15, 2010
    4,841
    3,052
    Yes 2203x
  9. shredless
    Sep 15, 2010
    4,841
    3,052
    The current mod is a 3 way zener /transistor/none clipper. Ive done cathode bypass changes which lm reviewing and learning how and why rather than just swap x for y, b+ drop, volume pot resistor, nfb res mod. I really like it at the moment but l always say that at first. It seems to get a little out of control bass wise at 5-6 on the master but maybe thats small room and me directly in front of it. Ive got the schem and a layout and lm studying what does what and why. Was confusing and l dint know a heater from a cathode or a grid or a anode. Whats the yellow wire, whys there a green on this one, etc
  10. shredless
    Sep 15, 2010
    4,841
    3,052
    This is what lm talking about being blind...l dont know what l did here exactly. Im sure l was following some mod page suggestion. But l thought this was a cap but it says 1.5k??? Anyone see one of these. I made a chart of everything l changed vs stock and this caught my eye...how l chose this l have no idea. I thought l was taking a 10k to 4.7k but turns out l replaced a 2.7k with 4.7k then did l actually parallel it with a 1.5k? I dont know what cap l thought l was doing. The differences in a layout pic vs my board vs schematic was twisting my brain. So lm seeing my mistakes lm not clear yet, my favorite color btw.
  11. shredless
    Sep 15, 2010
    4,841
    3,052
  12. South Park
    2,906
    2,403
    The values on capacitors suck to try to understand.What This 1.5 k means is 1 x 5 to the power of ten in negative numbers .
  13. neikeel
    4,624
    3,023
    That is an interesting choice for a cathode bypass cap. 1,500pF (0.0015uF).
  14. shredless
    Sep 15, 2010
    4,841
    3,052
    See and thought it was the angle of the dangle
  15. Im247frogs
    Im247frogs Well-Known Member
    Jan 31, 2012
    782
    999
    Brooklyn, Joey!
    extra holes are the bane of vintage resale value down the road. avoid at all costs.
    wakjob, South Park and shredless like this.
  16. shredless
    Sep 15, 2010
    4,841
    3,052
    Thank you... what signifies the pf? I believe my thinking was a 4.7k bypassed with a .1 or uf. I dint have a clear labeled .1 so l thought this was .15. maybe....
    I think my intention was to do the one just beside it...the 10k. And leave that 1st r1 as 2.7/.68. l think the 2203x rotates the pin config on the pre tubes. V1a is old school v1b. Like on my clipper l was told to place on pin 8 v2 but its actually pin 3 that has 33k, pin 8 is 820. Or lm l mistaken? Thats why lm in process of making a layout diagram as lf l was building a turret board so l can see better what lm doing. What would the effect of bypassing a 4.7 with a 1500pf? By the way, that combo goes to pin 8 v1...the next one over is unbypassed 2.7k to pin 3 v1 stock was 10k no cap. Preamp pot shield wire goes to pin 2 v1. Input jack shield goes to pin 7. I dint move any pin wires on the valves. Thanks for your time. :)
  17. neikeel
    4,624
    3,023
    1500pF (0.0015uF) is not really worth bothering with.
    Start with 0.1uF and build up to 1uF to make it worthwhile.
    thetragichero likes this.
  18. shredless
    Sep 15, 2010
    4,841
    3,052
    Yes, this is why lm hesitating
  19. shredless
    Sep 15, 2010
    4,841
    3,052
    I think that was the plan a 1 perhaps and l figgered 1.5 was close enough. I must by some caps for sure. Thanks again
  20. Sg-ocaster
    Sg-ocaster Well-Known Member
    Jun 1, 2020
    335
    364
    Yes or tuck the low input( unless you use it) into the chassis and put the switch in that hole.
    But yea don't drill.
