Mesa Boogie Mark IV - Rev A Clip
Discussion in 'Other Amps' started by Bxlxaxkxe, Jun 2, 2020.
  1. Bxlxaxkxe
    Bxlxaxkxe Active Member
    Oct 31, 2019
    37
    118
    Set up to sound C+ish
  2. ampmadscientist
    18,207
    12,290
    Nice Mesa Boogie Commercial.
    It sounds almost as good as a Marshall. Almost.
    You really gotta laugh about all the advertising Mesa plants in the Marshall Amp Forum.
    They don't even try to disguise what they are doing (anymore).
  3. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    1,438
    1,791
    Is that really the case? Didn’t the same guy demo a Marshall too?
  4. Buzzard
    Sep 14, 2016
    1,438
    1,791
    To be fair this is the “other amps “ section. I for one appreciate the demos. It’s all fun for me and he does a good job.plus he picks good songs that highlights the amps strengths.
    ricksdisconnected and Trelwheen like this.
  5. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,039
    1,001
    Yep, there is big money in advertising out of production amps. If I were running Mesa I would dump at least 30% of the companies money into running add's on the Mark 1 and 3, but targeting the Peavey and Vox forums. (That's where the big bucks are.)
    Trelwheen and Bxlxaxkxe like this.
  6. texhex
    texhex Well-Known Member
    Feb 1, 2016
    291
    434
  7. Bxlxaxkxe
    Oct 31, 2019
    37
    118
    Ha- You made my day with this comment man.
    There are some strange people out there. The internet is a great reminder of this
  8. ampeq
    Sep 14, 2017
    1,039
    1,001
    Always happy to help! Please keep up the good work, it’s a pleasure to check out your posts. I appreciate a lot of amp brands, and Mesa has always been top quality in my book. Love to see some Mark 2C+ “ads”.
    ricksdisconnected likes this.
  9. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    2,054
    3,691
    Texas
    Yep, sounds like a MkIV
    I like the hard tightness, but there's that something in the upper mids that scrapes my ears, it's in the preamp's distortion. Even my TC100 has a little of that sound when I dial the preamp gain up too much
    Great post, good playing and song choices
  10. ricksdisconnected
    Aug 11, 2019
    3,389
    4,528
    very nice. again marshall has nothing to answer this with.
    Trelwheen likes this.
  11. ricksdisconnected
    Aug 11, 2019
    3,389
    4,528
    what did they plant and where? (so we all can enjoy it too)
  12. Drinkingdeath01
    Drinkingdeath01 Well-Known Member
    Feb 1, 2010
    806
    1,797
    Minneapolis Minnesota
    The best way to get the upper mid out is run an OD pedal in front of it. Most people run the drive all the way down and the level around 3. Keeps from coloring the tone yet takes that ice pick mid out. Try it out, it made a big difference for me.
  13. texhex
    Feb 1, 2016
    291
    434
    I usually run a SD-1 with Level up and the Gain down in front of my Mark V. It lets me keep the amp Gain lower and keeps things tightened up. I'm not sure how well that would translate over to a IV but on the V (in IIC+ or IV mode and even in Crunch mode) running the amp Gain lower and letting the pedal push the front end works really well in my experience.
    Drinkingdeath01 likes this.
  14. ricksdisconnected
    Aug 11, 2019
    3,389
    4,528
    can ya not run a EQ pedal in the loop.
  15. Drinkingdeath01
    Feb 1, 2010
    806
    1,797
    You probably could but since it already has an EQ it never made much sense to run two at once. To me anyways.
  16. ricksdisconnected
    Aug 11, 2019
    3,389
    4,528
    you might be surprised. well, then again it might not work either in this case.
    do you have a EQ pedal you can try?
  17. Frehley12
    Frehley12 Member
    May 3, 2015
    49
    39
    Mark IVa owner here too. Thanks for posting. Didn't catch what speakers and cab you are playing through. Mine sounds amazing through a Marshall JCM800 4x12 with original g12-65s. Way better than a recto cab with v30s. Talk about a mid fest you can't really dial out. Go figure.
    Marks have a ton of mids. The OP used mid gain on top of it. I use harmonics and avoid v30s with this amp.
  18. dptone5
    dptone5 Well-Known Member
    Jan 31, 2010
    5,352
    4,205
    Pennsylvania
    That sounds terrific!!
  19. Del Rei
    Del Rei Well-Known Member
    Jun 26, 2013
    280
    378
    Great job, man.
    What did you use to record?
