waltschwarzkopf
- Joined
- Nov 30, 2021
- Messages
- 100
- Reaction score
- 96
Hello, World!
I’ve been thinking about a way to get natural OD at bedroom volumes and was thinking about the following.
Although both, the master volume and power soak, reduce the output volume, they operate in very different ways.
The master volume, on one hand, sends some of the pre-amp current to ground, and lets through the “needed” amount to the power amp, resulting in a lower volume. (Let’s assume there there is no power soak connected)
On the other hand, a power soak will dissipate some of the current after the output transformer, meaning the the speaker will receive only a fraction of this and therefore have less volume. (Let’s assume that there is no master volume here)
Some argue that a power soak “sounds better” as you get all the current flowing through the output stage and really get the tube(s) cooking. While others say that a master volume is the way to go as you can regulate the output without the need of additional devices.
WHAT DO YOU THINK?
Which method you prefer and why?
Cheers,
Walt
WHAT DO YOU THINK?
Cheers,
Walt
