Marshalls JCM800 2203/2204 or dual channels 2205/22010?
Discussion in 'Marshall Amps' started by Carlos G, Sep 25, 2020.
  1. Carlos G
    Carlos G Member
    Jan 6, 2020
    28
    27
    What is your opinion on these two different amps concerning sound and practicality? The 2203/2204 are single channels and the 2205/2210 dual channels but the latter are supposed to have an extra clipping diode that provides extra gain to the pre-amplifier changing their sound in a certain way, and in some opinions not as desirable. What is your take on this? Is it worth to sacrifice the extra channel to get the original sound or they are both as good?
  2. South Park
    2,966
    2,483
    The 2204 is the one to get . Diode clipping does not give you more gain it just clips the signal . Not the same as over drive sound
    Carlos G likes this.
  3. coolidge56
    coolidge56 Well-Known Member Double Platinum Supporting Member
    Jan 30, 2019
    1,005
    2,154
    WA state hinterlands
    Kind of apples to oranges comparison. Single channel vs dual channel, the diode clipping is kind of irrelevant. Assume it didn't have diode clipping you are back to single vs dual channel amp decision.
  4. JacksonCharvelAddict
    Mar 4, 2016
    1,885
    2,023
  5. Gain Man
    Gain Man Active Member
    Jan 13, 2009
    123
    40
    North Bavaria, Germany
    2203/2204 are classics and defined the sound of the 1980's. They don't have an effects loop though, unless you get a reissue. People love them, the sound is well known and I will lose no more words over them.
    A case can also be made for the 2210/2205. It has two channels and a loop. However here are some of the often mentioned issues with these amps:
    1. "The clean channel sounds terrible and doesn't even sound very clean"
    Now let's look at how the channels are labelled: "Boost Channel" and "Normal Channel".
    It isn't called "Normal Channel" and not "Clean Channel" for no reason. If you approach it with that in mind, a crunch channel with similarities to the 2203/2204 will unfold (with no diode clipping btw). Boost it with an OD pedal and off you go.
    If you run it on the edge of breakup and work with your guitar volume or gentle picking, it gets clean enough, but crystal clear? No, but then again: "Normal Channel".
    2. "The Boost Channel uses diode clipping."
    So what?
    It has 3 valve-driven gain stages and between two of these there are some clipping diodes. This diode clipping blends in, depending on how high you set your gain. Go up with the channel volume and you will hit the third gain stage harder, which warms up the signal.
    The Silver Jubilee also has a diode clipping circuit and is one the most highly praised Marshalls ever.
    So what?
    3. "The Boost Channel sounds compressed and lifeless"
    Maybe don't turn the gain higher that 8 or 9 at the most. If you need more distortion, boost it up front. Still sounds lifeless? Turn up the channel volume to 8 or 9 (some might say 10). If it still sounds lifeless, you are either deaf or dead.
    4. "There is this channel beeding problem"
    The Normal Channel bleeds into the Boost Channel, with clean notes being heared behind the wall of distortion.
    This was said to be fixed during the production years. My 2205 is from 1984 (which is still a fairly early one) and I have not experienced any noticeable channel bleed, except if I turn the Normal Channel volume to 10 and keep the Boost Channel volume very low, which would make the latter much much louder than the Boost Channel. Why on earth would you do that anyway?
    That's like building a container ship port on the shores of a duck pond.
    Summary:
    The 2210/2205 are easily misunderstood amps. The Boost Channel can sound like crap with the wrong settings, but sounds great if you know how. The Normal Channel is a mediocre clean channel, simply because that is what it isn't.
    Here are a few clips of them:
    Review by Leon Todd:
    Review by Javyon VISION:
    Review by David Evans (crappy audio, but you get the idea):
  6. Sg-ocaster
    Sg-ocaster Well-Known Member
    Jun 1, 2020
    392
    438
    Had a 2210 for along time.....it is a different flavor than a 2203.....bit more gain and imo a smoother slightly compressed tone in comparison....but really nice.
    Yes the normal bleeds in.....i used to adjust it to were it made the boost channel sound best and forget it and use it as 1 channel......that said I have not played a 2ch marshall that the 2 channels do not bleed to at least some extent.
  7. Musicmaniac
    Musicmaniac Well-Known Member
    Apr 10, 2013
    233
    311
    If you want a better clean sound use the 2204 if you want more crunch I use the 2205. I'm not a connoisseur of sound but for what I play I like both.
  8. NewReligion
    NewReligion Well-Known Member Double Platinum Supporting Member VIP Member
    Nov 17, 2009
    11,380
    8,507
    Paradise
    Stock? 2205/2210 Post 1986
    Modded? 2203/2204/1987/1959
    My $.02
  9. 67mike
    67mike Well-Known Member
    Mar 5, 2015
    762
    841
    I like the 2203/2204
  10. Carlos G
    Carlos G Member
    Jan 6, 2020
    28
    27
    Thanks for your input!
  11. Carlos G
    Carlos G Member
    Jan 6, 2020
    28
    27
    Sounds good! 2 channels are always appealing!
    NewReligion likes this.
