Marshall VS212
Discussion in 'Marshall Amps' started by Schaltzmann, Apr 13, 2021.
  1. Schaltzmann
    Schaltzmann New Member
    Apr 13, 2021
    11
    Hi does it possible to use a VS212 with a dsl1H 50th for the Ohms??? Thanks
    it’s writing 4ohm mono but 8ohm stéréo and on the Head 16 or 8 ohm ..
  2. fitz288
    fitz288 Space-Time Curver Silver Supporting Member
    Apr 7, 2020
    1,473
    3,097
    Pittsburgh, PA
    :welcome: to the forum.
    From what I can find, the VS212 is 2 x 8 ohm speakers wired for single 4 ohm input (parallel) or stereo with 2 x 8 ohm input.
    I'm not sure about the 8 ohm out on the DSL1H 50th.
    I have a DSL1H, and it's 16 ohm out only.
    If you rewired the VS212 to series wiring it would be 16 ohm and match the DSL1H, so that's a possible solution.
    tce63, Jethro Rocker and Maggot Brain like this.
  3. Jethro Rocker
    9,592
    13,602
    Yep that or run one side only at 8 ohms.
    tce63 and fitz288 like this.
  4. Schaltzmann
    Apr 13, 2021
    11
    On dsl1H i have on the same Out
    1w @ 16 ohm (8ohm min)
    on vs212 i have
    Mono inputs 4 OHM
    Right Input 8 ohm
    Left Input 8 Ohm
  5. fitz288
    Apr 7, 2020
    1,473
    3,097
    Pittsburgh, PA
    If the amp is ok with 8 ohm, you could use one of the stereo jacks, but that's just 1 speaker.
    Easy (no rewiring) solution is a Palmer Cab Merger.
    Plug into both stereo jacks @ 8 ohm, and use the series jack to amp @ 16 ohm.
    Jethro Rocker and SkyMonkey like this.
  6. Schaltzmann
    Apr 13, 2021
    11
  7. Schaltzmann
    Apr 13, 2021
    11
  8. Jethro Rocker
    9,592
    13,602
    Right. So plug amp out into right input jack and use just that speaker only.
    Or, get that gizmo pictured above.
    No other way to do it without rewiring the cab,
    fitz288 likes this.
  9. Schaltzmann
    Apr 13, 2021
    11
    Ok Thanks for your answer
    i will look for a 1912 or 1922
