Marshall VS100 power transformer
Discussion in 'The Workbench' started by Timbo, Oct 16, 2021.
  1. Timbo
    Timbo Active Member
    Oct 29, 2009
    186
    210
    Hi guys, I have a VS100 combo that is DOA and not wanting to be revived.
    Power transformer is good and will repurpose it.
    Would anyone know specs at all.
    Other wise.....
    It has a high voltage tap that powers the single 12ax7 (approx 240vac) with a protection fuse of 250mA, so the current capacity could be good for 3-4 12ax7s
    The 6.3v heater tap may be only good for one 12ax7 or relay power, has a 250mA protection fuse
    The 64v CT that powers the main circuit has no fuse, but a fusible resistor rated at .5w
    Put through a quadrupler could get approx 350vdc to power a pair of small output tubes, maybe around 120mAs
    Thoughts
  2. South Park
    3,671
    3,303
    Power ads so you need to know how much you have to work with . The heaters take the most the plates is next what tubes will work with it so what do you plan on building
  3. Timbo
    Timbo Active Member
    Oct 29, 2009
    186
    210
    Bassman/JTM45 circuit with 6V6 or EL84 output.
    Heaters will be a separate PT.
