hi i was wondering if the transformer in my 8008 is still ok because i measure 30 volts between red and black wire from transformer 30 volts between black and brown wire from tranny 30 volts between red and brown wire from tranny shouldn,t there be 59 volts between the red and black wire schematic in the link below
The two brown gets connected together on the pcb and then you get~60 volt red to black... why do you suspect the transformer?
hi i suspected the transformer cause i didnt measure 59 volts between red and black,but i figured out now that the brown wires are connected together and then i did measure 59 volts just like you wrote. thanks very much. so now i can start rebuilding ,new electrolytic filter caps ,new power transistors for channel a cause they were blown,new rectifier cause it was missing ,but first build a light bulb limiter ,so i wont blow all new parts when testing.
