Marshall Studio Classic Debate...help Us Settle It...
Discussion in 'Marshall Amps' started by FIREpunkMEDIC, Mar 17, 2019.
  1. marshallmellowed
    Jun 26, 2009
    5,025
    7,866
    Yeah, in the end, it doesn't really matter how you get to where you want to be. I think some just prefer to have their "diode clipping" external, for more control of that end result.
  2. Dogs of Doom
    25,768
    33,123
    Jose mod... :)...
    Gunner64 likes this.
  3. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,917
    2,422
    I'm looking at getting a new low-watt Marshall, but I need to know what's up with the effects loop level. Are all of them like this? I'm sick and tired of having to "fix" amplifiers that should have been thoroughly tested, prior to release. :pissed:
    tce63 likes this.
  4. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    4,259
    4,512
    detroit rock city
    My SV combo is fine no issues
    tce63 likes this.
  5. K2JLX
    K2JLX Well-Known Member Gold Supporting Member
    Apr 20, 2018
    396
    826
    The colonies
    SV head is fine here too, no issues with the loop.
    tce63 likes this.
  6. Len
    Len Well-Known Member
    Sep 13, 2009
    1,024
    797
    That’s been discussed to death in this and other forums.
  7. 67Mopar
    Jun 14, 2011
    1,917
    2,422
    I don't give a fuck. Tell me what the deal is on this amp. Is it a turd, or what?
  8. rrguitar1
    rrguitar1 Active Member
    Jul 8, 2017
    238
    170
    I also look forward in hearing how it holds up in a band situation. This amp is on my radar for sure. I just have to be confident that it will cut through for practice and live bar gigs.
  9. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    983
    894
    Cleveland, OH
    Its plenty loud enough.
    Best amp I've had.
    And I've owned every Marshall.
  10. marshallmellowed
    Jun 26, 2009
    5,025
    7,866
    If you're asking about the SC20, yes there's a volume drop when you engage the loop. The volume drop becomes less present as you increase the master volume of the amp, barely noticeable at higher volume settings (near max). "Is it a turd"? No, it sounds pretty good for a 20w amp. SV20 owners have reported that the loop volume drop does not exist on the SV20. I can't confirm that, as I haven't tried the SV20.
    Len and 67Mopar like this.
  11. 67Mopar
    Jun 14, 2011
    1,917
    2,422
    Well, so much for getting an SC20. Maybe Ceriatone will build a clone that operates properly.
  12. Moony
    Moony Well-Known Member
    Jul 3, 2015
    532
    622
    Post that on TGP and you will get hundreds of likes... :applause:
  13. 67Mopar
    Jun 14, 2011
    1,917
    2,422
    Why would the SC20 have a bum loop, but the SV20 does not?
  14. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    2,032
    2,632
    Södertälje, Sweden
    Probably has to do with signal level. The SV is non master volume, so signal level is pretty constant...I bet there is no drop when the master is on full...and the loop is not foot switchable, so the question it's if the loop works or not..volume drop issue?.. just turn up to compensate...
    GibsonKramer, 67Mopar, tce63 and 2 others like this.
  15. ken361
    Aug 30, 2009
    4,259
    4,512
    detroit rock city
    I use 2 mogami patch cables if that matters and a delay in my SV combo and Soul food up front. I still plugged in up front no problems less pedals the better:)
  16. 67Mopar
    Jun 14, 2011
    1,917
    2,422
    Sorry. I'm just spun-up after dealing with loop leveling and hum issues for the last three days. The SC20 sounds like the one for me, though I'd like to try the SV20 as well.
  17. SlyStrat
    Jan 7, 2011
    983
    894
    Cleveland, OH
    I never use a loop. My pedals go through the front the old school way.
    Never use reverb either. I make my own in a room.
    GibsonKramer likes this.
  18. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,265
    1,042
    Saginaw MI
    as said...op amps for effects loop..
    There are no diodes used in the signal path...only for power schemes, for AC rectification, bias circuits and keep current flowing in one direction...
  19. FIREpunkMEDIC
    FIREpunkMEDIC Member
    Apr 11, 2016
    53
    70
    You'd lose that bet Gunner. I play the old tried and true way. Guitar into amp, nothing between. So much for knowing EVERYTHING huh...
  20. FIREpunkMEDIC
    Apr 11, 2016
    53
    70
    By the way, was able to use it at band practice last night and it is KILLER. I'm pleased to say it is worth of carrying an "800" on the front panel.
