Marshall Studio Classic Debate...help Us Settle It...
Discussion in 'Marshall Amps' started by FIREpunkMEDIC, Mar 17, 2019.
  1. FIREpunkMEDIC
    FIREpunkMEDIC Member
    Apr 11, 2016
    53
    70
    Ok...so a band mate and I have a disagreement going on. Shed some light on this for us if you would...
    Marshall 2203 and 2204 all tube...NO diode clipping.
    Marshall 2205 and 2210...Diode clipping.
    Silver Jubilee and Mini...diode clipping.
    JCM 800 Studio Classic 20h...DIODES OR NO?
    After responses I will let ya know which side I was on...100% sure I'm right here though.
    CHEERS!
  2. Len
    Len Well-Known Member
    Sep 13, 2009
    1,024
    797
    I’m pretty sure no diodes.
    FIREpunkMEDIC likes this.
  3. Gunner64
    Nov 16, 2013
    7,333
    10,198
    Midwest, USA
    No. It's based on the 2203/2204.
  4. FIREpunkMEDIC
    Apr 11, 2016
    53
    70
    Two votes my way so far...P.S. he is aruing this with me even though I OWN one...haha!
  5. Moony
    Moony Well-Known Member
    Jul 3, 2015
    532
    622
    I've seen gutshots of the Classic and spotted two TL072 op amps and a transistor. And a diode (aside the rectifier ones) next to a relais.
    If you've got a schematic I can tell you what they are doing. :shrug:
    Tube-wise there is no need for simulating gain stages with op amps as you've got two 12AX7 in the preamp (the third is for the PI) like on the 2203.
    Adieu likes this.
  6. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    6,615
    7,858
    Montreal
    So you're saying yes?
    BP
  7. Moony
    Jul 3, 2015
    532
    622
    What do you mean, I would say? Don't understand that (English is not my mother tongue).
  8. Kinkless Tetrode
    Aug 17, 2017
    1,631
    2,388
    Might be for the loop. Might be for power scaling power supply needs.
  9. Moony
    Jul 3, 2015
    532
    622
    I don't know as I've got no schematics, that's what I've said.
  10. marshallmellowed
    Jun 26, 2009
    5,025
    7,866
    The Op Amp is for the loop, I traced it out when I had mine apart looking for a fix for the loop "volume drop" issue. I doubt there are any diodes associated with clipping, but without reverse engineering or schematics, it would be tough to tell (other than by the total absence of any diodes).
  11. BanditPanda
    Oct 19, 2015
    6,615
    7,858
    Montreal
    Moony when you said.... "I've seen gutshots of the Classic and spotted two TL072 op amps and a transistor. And a diode (aside the rectifier ones) next to a relais.
    I understood that you had seen ( spotted ) a diode.
    BP
    tce63 likes this.
  12. Kinkless Tetrode
    Aug 17, 2017
    1,631
    2,388
    It is common to use a diode in association with the power supply to a relay.
    tce63 likes this.
  13. BanditPanda
    Oct 19, 2015
    6,615
    7,858
    Montreal
    Ok thanks Kinky. Does not relate to the OP's diode clipping question then.
    BP
  14. Kinkless Tetrode
    Aug 17, 2017
    1,631
    2,388
    Probably not, but we don't know for sure without a schematic or tracing it all out.
    Moony, BanditPanda and tce63 like this.
  15. Moony
    Jul 3, 2015
    532
    622
    Yes, that's true! :agreed:
    That's why I mentioned that's next to a relais.
    Sooner or later, the schematics will be "leaked".
    I personally don't think, that any of the gain is provided by solid state components.
  16. FIREpunkMEDIC
    Apr 11, 2016
    53
    70
    So...emailed Marshall directly. The Studio Classic has NO diode clipping! What you saw was indeed for the effects loop! Boom...FOR THE WIN! HAHA. First band practice with the classic tonight...I'll report back.
  17. Gunner64
    Nov 16, 2013
    7,333
    10,198
    Midwest, USA
    Don't put a tube screamer or sd1 in front of it..or Bam! Diode clipping..:)
  18. marshallmellowed
    Jun 26, 2009
    5,025
    7,866
    Or is it "Boom", diode clipping.
    Michael Roe, Gunner64 and tce63 like this.
  19. Gunner64
    Nov 16, 2013
    7,333
    10,198
    Midwest, USA
    I think it's "Bam Boom! Diode clipping. Either way. Diode, no diode..who gives a shit as long as it sounds good and you dig it.
    My Favorite tone is a JCM800 2204 and a tube screamer set for clean boost, but I have a 2205 that's pretty damn close..with more or less a built in tube screamer. In the amp, in front of the amp, it's all clipping Diodes. I'd bet the op is using an overdrive or boost of some kind.
  20. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    983
    894
    Cleveland, OH
    It doesn't matter. It has great tone and loud enough for band.
    Mitchell Pearrow and ken361 like this.
