Marshall Straight In
Discussion in 'Marshall Amps' started by scozz, Dec 28, 2020.
  1. Edgar Frog
    Edgar Frog Well-Known Member
    Sep 18, 2020
    219
    471
    Santa Carla, CA
    Thanks for the heads up. Will have to check out the update for sure. :)
    scozz and Mitchell Pearrow like this.
  2. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,125
    2,100
    Friedman runt 50 , sounds like a cranked plexi at sensible levels plugged straight in , no boosts required ( has one built in if required) .
  3. Old Punker
    Old Punker Well-Known Member
    Jun 17, 2020
    733
    1,760
    Ontario, Canada
    ^ +1 on the SD-1. Can't imagine life without it! Pretty impressive for such an inexpensive bit of older technology.
    scozz, Neptical, GregM and 2 others like this.
  4. Mitchell Pearrow
    13,304
    25,014
    I agree,
    Love mine
    Cheers
    scozz, Neptical and Old Punker like this.
  5. crossroadsnyc
    Feb 5, 2009
    21,296
    20,649
    My YJM100 is the first amp I've owned that I can totally enjoy plugging straight into ... but, it has overdrive & reverb built in, does that count?
    SHREDNECK, Mitchell Pearrow and scozz like this.
  6. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,648
    1,699
    I can't believe more people on here don't use this pedal, http://www.ceriatone.com/horsebreaker/
    It's made for what most people seem to be doing with the TS and such. It also has a lot of flexibility in it because you have 2 different pedals that can be run in either way, one into the other. I ordered one just to try, I know the Klon is spot on but I know nothing about the Breaker side. We'll see when she gets here. I don't want to overtake the op's thread so I'll post a couple vids I found of it in Tone Zone if you want to see it used for just enhancing the sound.
  7. scozz
    Jul 20, 2008
    4,529
    10,293
    How are you using your SD1 Mitch? As a clean boost or are you adding some gain?
    Old Punker and Mitchell Pearrow like this.
  8. scozz
    Jul 20, 2008
    4,529
    10,293
    I agree with this, and for most of my playing life, I’ve done this. It just the last few years I’ve tried more and more pedals, just for some variety and curiosity.
    I like the some wet pedals in the loop. Until recently, I’ve never owned an amp with an effects loop. So I’m enjoying those pedals now, some, mainly because I’m a huge Gilmour fan!
  9. KelvinS1965
    KelvinS1965 Well-Known Member
    Nov 22, 2015
    315
    717
    Not sure if it counts with my Esquire or my Strat as I've fitted them both with a mid boost circuit like the Eric Clapton Strats have. So it's a bit like having a clean/mid boost pedal built in. However, I do often play straight into my Mini Jubilee or my SV20H. Takes a few seconds to adjust the settings if I change guitars, then I'm off.
    I only put a pedal board together recently as I got into a covers band. I've kept it small and simple, but it covers the sounds I need with my MJ set on the clean channel, but with the gain on the edge of breaking up. However, sometimes I practice the band set and just use the clean or dirty channel in the MJ depending on the song and it's close enough most of the time anyway. Could have bought an SC20H instead of a pile of pedals. :rolleyes:
    Old Punker and scozz like this.
  10. ampeq
    Sep 14, 2017
    1,648
    1,699
    My use of dirt type pedals was always for the lead, a lot of my amps over the years had a built in bump / boost or 2nd ch for leads anyway though. (I really like the master boost on Mesa amps.) I want a drive boost built in my new Chupa amp when I order it, something like the one in my Carvin X100B combo. It can be used on either channel and brings the whole amp up a few db, I want the same but adjustable. I do like a good tank reverb built in but not digital, the HX I have has very good reverbs in it. My favorite built in thing is a good 5-band EQ, you can do a ton with a good one. Carvin and Mesa have always had very good examples of these, I just don't find outboard ones to work as well. The 10-band MXR one is pretty good, someday I would love to try the outboard pedal Mesa has to see if it works as good as their built in model.
  11. Mitchell Pearrow
    13,304
    25,014
    As a clean boost
    Level full
    Tone half
    Drive 0
    That’s the way I have been using it for at least as long as I have had the Dsl40c’s.
    Thanks Scozz
    Mitch
  12. solarburnDSL50
    Aug 8, 2008
    17,486
    13,521
    Wetville
    It varies from amp to amp including guitar plugged in And guitarist.
    And it's straight in voicing may be the cats ass...or not.
    If we're talking vintage Marshall circuits? Then yeah man. So much to be had straight in. Love it.
    And when I want more punch? Not gain. I give her a pedal.
  13. scozz
    Jul 20, 2008
    4,529
    10,293
    That’s kinda what I thought Mitch, it seems to work really well with your Dsl40s.
    Thanks Buddy, Cheers! :cheers:
  14. Mitchell Pearrow
    13,304
    25,014
    It works great with the Origins as well.
    I don’t feel it colors the tone much but it does tighten it up, the other night I ran the MXR10 band eq and didn’t need the SD1.
    Cheers Scozz
    Mitch
  15. IOSEPHVS
    IOSEPHVS Well-Known Member
    Feb 10, 2020
    1,247
    1,516
    Ohio
    I use an EHX English MUFF'n ( think Plexi gain stage and tone stack in a pedal) because I can't stand the sound of the diode clipping circuit in the JCM602's OD channel.
    solarburnDSL50 likes this.
  16. David Keller
    David Keller New Member
    Oct 13, 2017
    16
    4
    Scozz,
    I sold all my effects about 6 years ago and play directly into a Marshall 1958X combo. I play Heritage and USA Hamers. The tone is beautiful.I wish I had done it sooner. Playing clean also makes you clean up your playing. No effects to hide behind.
    trax1139, scozz and solarburnDSL50 like this.
  17. Ramo
    Ramo Well-Known Member
    Feb 13, 2019
    484
    1,062
    In my case i dont like straight in, i only have od in front and delay in FX for leads. I think its as simple as it can be :)
  18. Andy79
    Andy79 Member
    Aug 21, 2020
    12
    28
    Every time I use my amp, whether it’s my SV20h or old JTM30 combo, I always play straight in for some of the time, maybe half of the session.
    Currently putting all my pedals onto a board with a true bypass loop switcher (3 loops is enough for me) so that I can easily remove all pedals from the signal chain with a button press, rather than disconnecting stuff.
  19. scozz
    Jul 20, 2008
    4,529
    10,293
    Yeah, I’ve got a 7 band eq pedal, and it works and sounds great! I used that pedal all the time before I bought a Spark Boost.
    I like an eq pedal, I love the way it can be targeted to increase or decrease a certain frequency range. Perfect for sculpting certain tones.
    Cheers buddy!
  20. solarburnDSL50
    Aug 8, 2008
    17,486
    13,521
    Wetville
    When I was playing out live at clubs/dives I had 2 EQ's in loop. Both were set for different solo settings. The toe tapping wasn't that hard and I got to bring out frequencies I wanted for lead playing.
    I really didn't use them for rhythm playing. Yeah they do well there too but if you play lead? EQ's in loop do it.
